I having a problem with my sketch. It was work fine before and all of a sudden when i changed a board from mega to uno its not read my LDR, the LDR is fine i tested.
The serial monitor showing a following:
Starting
LDR Level: 0Threshold:330
Light Active
Top PIR Triggered
and thats it ![]()
Please note, Not i write the sketch.
THANK YOU FOR READING
// = Libraries required =//
#include <Bounce2.h>
// = Pin Allocations =//
#define Step1LEDPin 2 // the LEDs are connected to sequentional pins starting at this pin
#define Step2LEDPin 3 // the LEDs are connected to sequentional pins starting at this pin
#define Step3LEDPin 4 // the LEDs are connected to sequentional pins starting at this pin
#define Step4LEDPin 5 // the LEDs are connected to sequentional pins starting at this pin
#define Step5LEDPin 6 // the LEDs are connected to sequentional pins starting at this pin
#define PIRTop A1
#define PIRBottom A0
#define LDR A3
// = Contsants =//
#define LightThresholdLevel 330
#define LEDStepTime 400 // miliseconds
#define LEDOnTime 7000 // miliseconds
#define filterSamples 25
// = Global Variables =//
uint8_t SequenceLoop = 0;
int RawADC = 0;
int LightLevel = 0;
// = Low Pass Filter Variables =//
int DS_J_Loop;
int DS_K_Loop;
int DS_Temp;
int DS_Top;
int DS_Bottom;
long DS_Total;
int DS_ArrayPointer;
int DS_FilterArray[filterSamples];
boolean DS_SortDone = false;
// = PIR State Structure =//
struct PIRState
bool Change;
bool State;
bool LastState;
} State_PIR_Top,State_PIR_Bottom;
// = PIR input Definitions =//
Bounce B_PIR_TOP = Bounce();
Bounce B_PIR_Bottom = Bounce();
// Timer ISR Handler //
// = Set Everything up //
Serial.println("Starting");
pinMode(Step1LEDPin, OUTPUT);
pinMode(Step2LEDPin, OUTPUT);
pinMode(Step3LEDPin, OUTPUT);
pinMode(Step4LEDPin, OUTPUT);
pinMode(Step5LEDPin, OUTPUT);
pinMode(PIRTop, INPUT_PULLUP);
pinMode(PIRBottom, INPUT_PULLUP);
B_PIR_TOP.attach(PIRTop);
B_PIR_Bottom.attach(PIRBottom);
Allon();
delay(7000);
Alloff();
//= Run The Loop //
RawADC = analogRead(LDR);
LightLevel = digitalSmooth(RawADC, DS_FilterArray);
Serial.print("LDR Level : ");
Serial.print(LightLevel);
Serial.print("Threshold : ");
Serial.println(LightThresholdLevel);
B_PIR_TOP.update();
B_PIR_Bottom.update();
if (LightLevel <= LightThresholdLevel)
Serial.println("Light Active");
if (B_PIR_TOP.read())
Serial.println("Top PIR Triggered");
digitalWrite(Step1LEDPin, LOW);
delay(LEDStepTime);
digitalWrite(Step2LEDPin, LOW);
delay(LEDStepTime);
digitalWrite(Step3LEDPin, LOW);
delay(LEDStepTime);
digitalWrite(Step4LEDPin, LOW);
delay(LEDStepTime);
digitalWrite(Step5LEDPin, LOW);
delay(LEDStepTime);
delay(LEDOnTime);
B_PIR_TOP.update();
while (B_PIR_TOP.read())
B_PIR_TOP.update();
delay(LEDStepTime);
digitalWrite(Step1LEDPin, HIGH);
delay(LEDStepTime);
digitalWrite(Step2LEDPin, HIGH);
delay(LEDStepTime);
digitalWrite(Step3LEDPin, HIGH);
delay(LEDStepTime);
digitalWrite(Step4LEDPin, HIGH);
delay(LEDStepTime);
digitalWrite(Step5LEDPin, HIGH);
delay(LEDStepTime);
Alloff();
else if (B_PIR_Bottom.read())
Serial.println("Bottom PIR Triggered");
delay(LEDStepTime);
delay(LEDStepTime);
delay(LEDStepTime);
delay(LEDStepTime);
delay(LEDOnTime);
while (B_PIR_Bottom.read())
delay(LEDStepTime);
delay(LEDStepTime);
delay(LEDStepTime);
delay(LEDStepTime);
delay(LEDStepTime);
Alloff();
// Turn All LEDs off //
void Alloff()
void Allon()
// ADC Lowpass Filter //
int digitalSmooth(int rawIn, int *sensSmoothArray)
DS_ArrayPointer = (DS_ArrayPointer + 1) % filterSamples;
sensSmoothArray[DS_ArrayPointer] = rawIn;
for (DS_J_Loop = 0; DS_J_Loop<filterSamples; DS_J_Loop++)
DS_FilterArray[DS_J_Loop] = sensSmoothArray[DS_J_Loop];
while (!DS_SortDone)
DS_SortDone = true;
for (DS_J_Loop = 0; DS_J_Loop < (filterSamples - 1); DS_J_Loop++)
if (DS_FilterArray[DS_J_Loop] > DS_FilterArray[DS_J_Loop + 1])
DS_Temp = DS_FilterArray[DS_J_Loop + 1];
DS_FilterArray[DS_J_Loop + 1] = DS_FilterArray[DS_J_Loop];
DS_FilterArray[DS_J_Loop] = DS_Temp;
DS_Bottom = max(((filterSamples * 15) / 100), 1);
DS_Top = min((((filterSamples * 85) / 100) + 1), (filterSamples - 1));
DS_K_Loop = 0;
DS_Total = 0;
for (DS_J_Loop = DS_Bottom; DS_J_Loop< DS_Top; DS_J_Loop++)
DS_Total += DS_FilterArray[DS_J_Loop];
DS_K_Loop++;
return DS_Total / DS_K_Loop;
