Hi guys,
Re :drag racing timing program :phototransistor sensors
I loaded a sketch into the Mega for this program :
My issue here per my cousin who is helping me, i have "no knowledge," just trying to learn, he is saying once we load the below sketch, pin 48, input, no voltage , but once we assign pin 48 to "start Lane 1, it goes " high ," and we have continuous voltage, given this is a phototransistor sensors , once the car goes over it he is stating it should trigger a "high and low".
But staying high, any suggestion on what to try to get this to work ?
#include <TM1637Display.h>
// Pines para los displays
#define CLK_REACCION_1 3
#define DIO_REACCION_1 2
#define CLK_CARRERA_1 6
#define DIO_CARRERA_1 7
#define CLK_REACCION_2 8
#define DIO_REACCION_2 9
#define CLK_CARRERA_2 11
#define DIO_CARRERA_2 10
// Pines para los sensores LDR
#define LDR_INICIO_CARRIL_1 A5
#define LDR_FINAL_CARRIL_1 A4
#define LDR_INICIO_CARRIL_2 A6
#define LDR_FINAL_CARRIL_2 A7
// Pines para los LEDs
#define LED_AMARILLO_CARRIL_1 A0
#define LED_VERDE_CARRIL_1 13
#define LED_ROJO_CARRIL_1 12
#define LED_AMARILLO_CARRIL_2 A3
#define LED_VERDE_CARRIL_2 A1
#define LED_ROJO_CARRIL_2 A2
// Pines para los pulsadores de Bracket
#define PULSADOR_BRACKET_CARRIL_1 5
#define PULSADOR_BRACKET_CARRIL_2 4
// Displays
TM1637Display displayReaccion1(CLK_REACCION_1, DIO_REACCION_1);
TM1637Display displayCarrera1(CLK_CARRERA_1, DIO_CARRERA_1);
TM1637Display displayReaccion2(CLK_REACCION_2, DIO_REACCION_2);
TM1637Display displayCarrera2(CLK_CARRERA_2, DIO_CARRERA_2);
// Variables globales
unsigned long tiempoInicioCarrera1 = 0;
unsigned long tiempoInicioCarrera2 = 0;
unsigned long tiempoReaccion1 = 0;
unsigned long tiempoReaccion2 = 0;
unsigned long tiempoCarrera1 = 0;
unsigned long tiempoCarrera2 = 0;
int bracket1 = 0;
int bracket2 = 0;
const int ldrInicio1 = A5;
const int ldrInicio2 = A6;
const int ldrFinal1 = A4;
const int ldrFinal2 = A7;
int valor0inicio1;
int valor0inicio2;
int valor0final1;
int valor0final2;
const int umbral = 50;
bool stage1 = false;
bool stage2 = false;
bool reaccionMedida1 = false;
bool reaccionMedida2 = false;
bool ledVerdeEncendido1 = false;
bool ledVerdeEncendido2 = false;
bool carreraFinalizada1 = false;
bool carreraFinalizada2 = false;
// Variables para la secuencia de luces
unsigned long tiempoInicioSecuencia = 0;
unsigned long tiempoDesdeStage1 = 0; // Variable para contar el tiempo desde que ambos coches están en stage en el carril 1
unsigned long tiempoDesdeStage2 = 0; // Variable para contar el tiempo desde que ambos coches están en stage en el carril 2
bool secuenciaEnProceso = false;
int estadoSecuencia1 = 0;
int estadoSecuencia2 = 0;
// Debounce variables
unsigned long lastDebounceTime1 = 0;
unsigned long lastDebounceTime2 = 0;
const unsigned long debounceDelay = 300;
// Variables para el intervalo de seguridad
unsigned long tiempoUltimaLecturaFinal1 = 0;
unsigned long tiempoUltimaLecturaFinal2 = 0;
const unsigned long intervaloSeguridad = 300; // 300 ms de intervalo de seguridad
// Variables para controlar si se debe seguir leyendo los LDR finales e iniciales
bool seguirLeyendoLDRFinal1 = true;
bool seguirLeyendoLDRFinal2 = true;
bool seguirLeyendoLDRInicio1 = true;
bool seguirLeyendoLDRInicio2 = true;
// Variables para detectar salida en falso
bool salidaEnFalsoDetectada1 = false;
bool salidaEnFalsoDetectada2 = false;
// Funciones
// Inicialización de pines
pinMode(LDR_INICIO_CARRIL_1, INPUT);
pinMode(LDR_FINAL_CARRIL_1, INPUT);
pinMode(LDR_INICIO_CARRIL_2, INPUT);
pinMode(LDR_FINAL_CARRIL_2, INPUT);
pinMode(LED_AMARILLO_CARRIL_1, OUTPUT);
pinMode(LED_VERDE_CARRIL_1, OUTPUT);
pinMode(LED_ROJO_CARRIL_1, OUTPUT);
pinMode(LED_AMARILLO_CARRIL_2, OUTPUT);
pinMode(LED_VERDE_CARRIL_2, OUTPUT);
pinMode(LED_ROJO_CARRIL_2, OUTPUT);
pinMode(PULSADOR_BRACKET_CARRIL_1, INPUT_PULLUP);
pinMode(PULSADOR_BRACKET_CARRIL_2, INPUT_PULLUP);
// Inicialización de displays
displayReaccion1.setBrightness(2);
displayCarrera1.setBrightness(2);
displayReaccion2.setBrightness(2);
displayCarrera2.setBrightness(2);
displayReaccion1.clear();
displayCarrera1.clear();
displayReaccion2.clear();
displayCarrera2.clear();
valor0inicio1 = analogRead(ldrInicio1);
valor0inicio2 = analogRead(ldrInicio2);
valor0final1 = analogRead(ldrFinal1);
valor0final2 = analogRead(ldrFinal2);
// Mostrar "0" al inicio en displays de tiempo de reacción
displayReaccion1.showNumberDec(0);
displayReaccion2.showNumberDec(0);
displayCarrera1.showNumberDec(0);
displayCarrera2.showNumberDec(0);
// Manejar el tiempo de configuración del bracket
manejarBracketConTiempo(60000); // Hasta 1 minuto para ajustar el bracket
// Asegurarse de que los displays de tiempo de reacción muestren "0000" al finalizar el ajuste del bracket
displayReaccion1.showNumberDec(0, true);
displayReaccion2.showNumberDec(0, true);
// Iniciar la secuencia de luces solo cuando ambos coches estén en stage
while (!(stage1 && stage2)) {
lecturasLDR(); // Actualizar el estado de los coches en stage
// Registrar el tiempo desde que ambos coches están en stage
tiempoDesdeStage1 = millis();
tiempoDesdeStage2 = millis();
iniciarSecuenciaDeLuces();
void manejarBracketConTiempo(unsigned long tiempoMaximo) {
unsigned long startTime = millis();
unsigned long lastButtonPressTime = millis();
while (millis() - startTime < tiempoMaximo) {
if (millis() - lastButtonPressTime > 5000) {
break; // Terminar si no se presiona ningún botón en 5 segundos
if (manejarBracket()) {
lastButtonPressTime = millis(); // Actualizar el tiempo de la última pulsación de botón
bool manejarBracket() {
bool buttonPressed = false;
if (digitalRead(PULSADOR_BRACKET_CARRIL_1) == LOW) {
if ((millis() - lastDebounceTime1) > debounceDelay) {
bracket1 += 50;
displayReaccion1.showNumberDec(bracket1, false);
lastDebounceTime1 = millis();
buttonPressed = true;
if (digitalRead(PULSADOR_BRACKET_CARRIL_2) == LOW) {
if ((millis() - lastDebounceTime2) > debounceDelay) {
bracket2 += 50;
displayReaccion2.showNumberDec(bracket2, false);
lastDebounceTime2 = millis();
return buttonPressed;
void iniciarSecuenciaDeLuces() {
secuenciaEnProceso = true;
tiempoInicioSecuencia = millis();
void secuenciaDeLuces() {
unsigned long tiempoSecuencia1 = 1000 + bracket1;
unsigned long tiempoSecuencia2 = 1000 + bracket2;
// Detectar salida en falso mientras está la secuencia en proceso
int valor1inicio1 = analogRead(ldrInicio1);
int valor1inicio2 = analogRead(ldrInicio2);
if (!ledVerdeEncendido1 && !carreraFinalizada1 && stage1 && currentMillis - tiempoDesdeStage1 >= 1 && valor1inicio1 >= valor0inicio1) {
salidaEnFalsoDetectada1 = true;
digitalWrite(LED_ROJO_CARRIL_1, HIGH);
digitalWrite(LED_VERDE_CARRIL_2, HIGH);
digitalWrite(LED_AMARILLO_CARRIL_1, LOW); // Apagar LED amarillo
digitalWrite(LED_AMARILLO_CARRIL_2, LOW); // Apagar LED amarillo
displayReaccion1.showNumberDec(8888);
displayCarrera1.showNumberDec(8888);
displayCarrera2.showNumberDec(0, true);
return;
if (!ledVerdeEncendido2 && !carreraFinalizada2 && stage2 && currentMillis - tiempoDesdeStage2 >= 1 && valor1inicio2 >= valor0inicio2) {
salidaEnFalsoDetectada2 = true;
digitalWrite(LED_ROJO_CARRIL_2, HIGH);
digitalWrite(LED_VERDE_CARRIL_1, HIGH);
displayReaccion2.showNumberDec(8888);
displayCarrera2.showNumberDec(8888);
displayCarrera1.showNumberDec(0, true);
return;
if (secuenciaEnProceso) {
// Manejar secuencia para carril 1
switch (estadoSecuencia1) {
case 0:
if (currentMillis - tiempoInicioSecuencia >= tiempoSecuencia1) {
digitalWrite(LED_AMARILLO_CARRIL_1, HIGH);
estadoSecuencia1 = 1;
case 1:
if (currentMillis - tiempoInicioSecuencia >= tiempoSecuencia1 + 400) {
ledVerdeEncendido1 = true;
tiempoInicioCarrera1 = millis();
estadoSecuencia1 = 2;
// Manejar secuencia para carril 2
switch (estadoSecuencia2) {
case 0:
if (currentMillis - tiempoInicioSecuencia >= tiempoSecuencia2) {
digitalWrite(LED_AMARILLO_CARRIL_2, HIGH);
estadoSecuencia2 = 1;
case 1:
if (currentMillis - tiempoInicioSecuencia >= tiempoSecuencia2 + 400) {
ledVerdeEncendido2 = true;
tiempoInicioCarrera2 = millis();
estadoSecuencia2 = 2;
// Si ambas secuencias han terminado
if (estadoSecuencia1 == 2 && estadoSecuencia2 == 2) {
void lecturasLDR() {
if (salidaEnFalsoDetectada1 || salidaEnFalsoDetectada2) {
return; // Si se ha detectado una salida en falso en algún carril, detener todos los procesos
int valor1final1 = analogRead(ldrFinal1);
int valor1final2 = analogRead(ldrFinal2);
// Detectar si los coches están en stage
if (seguirLeyendoLDRInicio1 && valor1inicio1 < valor0inicio1 - umbral) {
stage1 = true;
if (seguirLeyendoLDRInicio2 && valor1inicio2 < valor0inicio2 - umbral) {
stage2 = true;
// Detectar salida en falso para carril 1
return;
// Detectar salida en falso para carril 2
return;
// Detectar tiempo de reacción
if (ledVerdeEncendido1 && !reaccionMedida1 && valor1inicio1 >= valor0inicio1) {
tiempoReaccion1 = currentMillis - tiempoInicioCarrera1;
displayReaccion1.showNumberDecEx(tiempoReaccion1, 0b10000000, true);
reaccionMedida1 = true;
seguirLeyendoLDRInicio1 = false; // Dejar de leer el LDR de inicio
if (ledVerdeEncendido2 && !reaccionMedida2 && valor1inicio2 >= valor0inicio2) {
tiempoReaccion2 = currentMillis - tiempoInicioCarrera2;
displayReaccion2.showNumberDecEx(tiempoReaccion2, 0b10000000, true);
reaccionMedida2 = true;
seguirLeyendoLDRInicio2 = false; // Dejar de leer el LDR de inicio
// Detectar fin de carrera con intervalo de seguridad
if (ledVerdeEncendido1 && seguirLeyendoLDRFinal1 && valor1final1 < valor0final1 - umbral) {
if (currentMillis - tiempoUltimaLecturaFinal1 > intervaloSeguridad) {
tiempoCarrera1 = currentMillis - tiempoInicioCarrera1;
displayCarrera1.showNumberDecEx(tiempoCarrera1, 0b10000000, true);
seguirLeyendoLDRFinal1 = false;
carreraFinalizada1 = true;
digitalWrite(LED_VERDE_CARRIL_1, LOW);
// Verificar si es el primer coche en cruzar la meta
if (!carreraFinalizada2) {
digitalWrite(LED_VERDE_CARRIL_1, HIGH); // Encender LED verde del carril 1
tiempoUltimaLecturaFinal1 = currentMillis;
if (ledVerdeEncendido2 && seguirLeyendoLDRFinal2 && valor1final2 < valor0final2 - umbral) {
if (currentMillis - tiempoUltimaLecturaFinal2 > intervaloSeguridad) {
tiempoCarrera2 = currentMillis - tiempoInicioCarrera2;
displayCarrera2.showNumberDecEx(tiempoCarrera2, 0b10000000, true);
seguirLeyendoLDRFinal2 = false;
carreraFinalizada2 = true;
digitalWrite(LED_VERDE_CARRIL_2, LOW);
if (!carreraFinalizada1) {
digitalWrite(LED_VERDE_CARRIL_2, HIGH); // Encender LED verde del carril 2
tiempoUltimaLecturaFinal2 = currentMillis;
return; // Si se ha detectado una salida en falso en algún carril, detener el loop
secuenciaDeLuces();
lecturasLDR();
