I'm not sure if this is a bit of a silly question but,
Can I plug nodemcu esp8266 into wall using its usb port and a phone adapter and if i can do that how much energy will it consume
Yes, you can power a NodeMCU with a 5volt USB cellphone charger.
The NodeMCU draws about 100mA, so consumes about 5volt * 0.1Amp = 0.5watt.
Less than 1watt total if you also count the power loss in the supply.
Leo..
The energy consumption also depends on what the code is doing...
It only drops when using sleepmodes.
Otherwise it stays rather constant.
Leo..
I think the 2.4GHz radio uses power, it may not always be on.
The radio uses quite a bit of power when transmitting.
The NodeMCU boards have on board voltage regulator and power supply capacitors that mostly average this out, but it's a concern if one is using an ESP-01 or similar board without on board regulation.
Link shows current profile of an ESP-01: https://www.researchgate.net/publication/305649843_Power_analysis_of_local_transmission_technologies
