CanBus Filtering
Please someone can solve this filter for me i want just get the data with id=8CF00400 as highlighted in the picture attached.
// MCP2515 Mask and Filter example for extended CAN message frames.
// Written by Cory J. Fowler (20140717)
If you send the following extended IDs below to an Arduino loaded with this sketch
you will find that 0x00FFCC00 and 0x00FF9900 will not get in.
   ID in Hex is the same as the Filter in Hex.
   0x00FFEE00
   0x00FFDD00
   0x00FFCC00  This example will NOT be receiving this ID
   0x00FFBB00
   0x00FFAA00
   0x00FF9900  This example will NOT be receiving this ID
   0x00FF8800
   0x00FF7700
   This mask will check the filters against ID bits 23 through 8.
   (Those familiar with J1939 might see why I used this mask.)
    MASK = 0x00FFFF00
   If there is an explicit filter match to those bits, the message will be passed to the
   receive buffer and the interrupt pin will be set.
   This example will NOT be exclusive to ONLY the above message IDs, for that a mask such
   as the below would be used:
    MASK = 0x1FFFFFFF
   At the moment, to disable a filter or mask, copy the value of a used filter or mask.
#include <mcp_can.h>
#include <SPI.h>
long unsigned int rxId;
unsigned char len = 0;
unsigned char rxBuf[8];
MCP_CAN CAN0(49);  // Set CS to pin 10
  digitalWrite(53, OUTPUT);
  if (CAN0.begin(MCP_STDEXT, CAN_500KBPS, MCP_8MHZ) == CAN_OK) Serial.print("MCP2515 Init Okay!!\r\n");
  else Serial.print("MCP2515 Init Failed!!\r\n");
  pinMode(2, INPUT);  // Setting pin 2 for /INT input
  CAN0.init_Mask(0, 0, 0x07FFFFFF);
  CAN0.init_Filt(0, 0, 0x02908000);
  CAN0.init_Filt(1, 0, 0x02908000);
  CAN0.init_Mask(1, 0, 0x07FFFFFF);
  CAN0.init_Filt(2, 0, 0x02908000);
  CAN0.init_Filt(3, 0, 0x02908000);
  CAN0.init_Filt(4, 0, 0x02908000);
  CAN0.init_Filt(5, 0, 0x02908000);
  Serial.println("MCP2515 Library Mask & Filter Example...");
  CAN0.setMode(MCP_NORMAL);  // Change to normal mode to allow messages to be transmitted
  if (!digitalRead(2))  // If pin 2 is low, read receive buffer
    CAN0.readMsgBuf(&rxId, &len, rxBuf);  // Read data: len = data length, buf = data byte(s)
    Serial.print("ID: ");
    Serial.print(rxId, HEX);
    Serial.print(" Data: ");
    for (int i = 0; i < len; i++)  // Print each byte of the data
      if (rxBuf[i] < 0x10)  // If data byte is less than 0x10, add a leading zero
        Serial.print("0");
      Serial.print(rxBuf[i], HEX);
      Serial.print(" ");
END FILE
Moved to Programming Questions.... Please try not to post in Uncategorized again.
start experiments with
uint32_t mymask =      0xFFFFFFFF;  // check all bits
uint32_t myfilter =    0x8CF00400;  //  bits must be set to this
  CAN0.init_Mask(0, 0, mymask);
  CAN0.init_Filt(0, 0, myfilter);
  CAN0.init_Filt(1, 0, myfilter);
  CAN0.init_Mask(1, 0, mymask);
  CAN0.init_Filt(2, 0, myfilter);
  CAN0.init_Filt(3, 0, myfilter);
  CAN0.init_Filt(4, 0, myfilter);
  CAN0.init_Filt(5, 0, myfilter);
Thanks A lot it worked for me
But how my mask is ffffffff please
you said you only want to see exactly one ID. Therefore the full mask has to be activated.
write it down in binary:
0b11111111111111111111111111111111; // the mask
0b10001100111100000000010000000000; // 0x8FC00400
the mask defines which bit positions must be checked --> in your case all
the filter defines how the bit must be set at that position.
ps.: now you can reduce your filters
that should work too
  //CAN0.init_Filt(1, 0, myfilter);
  //CAN0.init_Filt(2, 0, myfilter);
  //CAN0.init_Filt(3, 0, myfilter);
  //CAN0.init_Filt(4, 0, myfilter);
  //CAN0.init_Filt(5, 0, myfilter);
should be
CAN0.init_Mask(0, 0, 0x1FFFFFFF); //for typical 29bit extended CAN ID
in your case, your want to filter for "0x8CF00400" which is 32 bits long. therefore you need to check all the bits as proposed by @noiasca
btw keep the code from post #3. post #6 code will NOT filter correctly!
hope that helps...
Continuing the discussion from CanBus Filtering:
Hi Noiasca The above filters and masks you suggested work, but only for one ID, 0X8CF00400. As soon as I added a second filter to get 0X98FEEE00, it was still the same, giving me 0X8CF00400, but I need both 0X8CF00400 and 0X98FEEE00.
MY FILTERS AND MASKS ARE AS FOLLOWS
The output from this setup is only 0X8CF00400 and is missing 0X98FEEE00.
Can you please suggest a solution?
uint32_t mymask_1 =      0xFFFFFFFF;  // check all bits
uint32_t myfilter_1 =    0x98FEEE00;  //  bits must be set to this
  CAN0.init_Mask(1, 0, mymask_1);
  CAN0.init_Filt(2, 0, myfilter_1);
since u are using extended CAN IDs
should be
CAN0.init_Mask(0, 1, mymask); //as for the 2nd mask as well :wink:
and
should be
CAN0.init_Filt(0, 1, myfilter); // as for the remaining filters :wink:
'0' disables extended CAN ID filtering and all applied it to standard 11 bits CAN ID
hope that helps....
