Hi im needing help with a sketch that ive modified that i cant get to work correctly.
What im trying to achieve is using a UNO, CANBUS shield and a LCD shield plugged into my car then pull the speed and RPM from the CANBUS line and display them onto LCD.
I can get it to work but not correctly the information displayed is randomly mixed up and irractic but the figures that do come up are correct but in the wrong place.
I think that its somthing to do with buffer array but im not sure??
#include <LiquidCrystal.h>
#include <Canbus.h>
#include <defaults.h>
#include <global.h>
#include <mcp2515.h>
#include <mcp2515_defs.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(8,9,4,5,6,7);
//Declare CAN variables for communication
int EngineRPM;
int VehicleSpeed;
char buffer[64]; //Data will be temporarily stored to this buffer before being written to the file
//********************************Setup Loop*********************************//
//Initialize Serial communication for debugging
Serial.println("ECU Demo");
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
lcd.clear();
//Initialize CAN Controller
if(Canbus.init(CANSPEED_500)) /* Initialize MCP2515 CAN controller at the specified speed */
lcd.clear();
lcd.setCursor(0,0); // Sets the cursor to col 0 and row 0
lcd.print("CAN Init ok");
Serial.println("CAN Init Ok");
delay(1500);
lcd.clear();
lcd.print("Can't init CAN");
Serial.println("Can't init CAN");
return;
//********************************Main Loop*********************************//
void loop(){
Canbus.ecu_req(ENGINE_RPM,buffer); //Request engine RPM
EngineRPM = buffer;
Serial.print("RPM: "); //Uncomment for Serial debugging
Serial.println(buffer);
lcd.clear();
lcd.print("RPM ");
lcd.print(buffer);
Canbus.ecu_req(VEHICLE_SPEED,buffer); //Request engine RPM
VehicleSpeed = buffer;
Serial.print("SPEED: "); //Uncomment for Serial debugging
lcd.setCursor(0,1); // Sets the cursor to col 0 and row 0
lcd.print("SPEED ");
lcd.print(buffer);
EngineRPM = buffer;
lcd.clear();
lcd.print("RPM ");
lcd.print(buffer);
to this
EngineRPM = Canbus.ecu_req(ENGINE_RPM,buffer); //Request engine RPM
lcd.clear();
lcd.print("RPM ");
lcd.print(buffer);
or this with Serial.println and the lcd.print changed from "buffer" to "EngineRPM"
Serial.println(EngineRPM);
lcd.clear();
lcd.print("RPM ");
lcd.print(EngineRPM);
Ive tried the suggested mod to the sketch and it has made no difference it flashes between RPM and SPEED figures on both lines of the LCD is it somthing to do with "buffer"?????
// include the library code:
#include <Canbus.h>
#include <global.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int EngineRPM;
int VehicleSpeed;
lcd.begin(16, 2);
lcd.clear();
if (Canbus.init(CANSPEED_500)) /* Initialize MCP2515 CAN controller at the specified speed */
lcd.clear();
lcd.setCursor(0, 0); // Sets the cursor to col 0 and row 0
delay(1500);
lcd.clear();
return;
EngineRPM = Canbus.ecu_req(ENGINE_RPM, buffer); //Request engine RPM
lcd.clear();
lcd.print("RPM ");
lcd.print(buffer);
VehicleSpeed = Canbus.ecu_req(VEHICLE_SPEED, buffer); //Request vehicle speed
lcd.setCursor(0, 1); // Sets the cursor to col 0 and row 0
lcd.print(buffer);
delay(100);
I’ve tried changing it from “buffer” to EngineRPM and Speed but all that does is create alarms on the car kills the RPM gauge and all the lights come up on the dash and the car revs up by itself. So maybe this isn’t the way to go??
and gutted it to try and make it work for my application. If I just have the sketch to only read the RPM or the SPEED it works fine just have problems when trying to do both at same time.
Focusmad:
Sending data to the lcd display doesn't really affect your car. Try posting actual code since I am very dubious of our claims.
char buffer[512]; //Data will be temporarily stored to this buffer before being written to the file
if (Canbus.ecu_req(ENGINE_RPM, buffer) == 1) /* Request for engine RPM */
sLCD.write(COMMAND); /* Move LCD cursor to line 0 */
sLCD.write(LINE0);
sLCD.print(buffer); /* Display data on LCD */
And you are doing:
Looks like the .ecu_req() function returns a 1 to indicate if the read was successful. You should check for that 1 before using the contents of 'buffer'.
Are you sure your buffer is large enough? You dropped it from 512 to 64.
Are your sure you are getting results? Without checking the return value you can't tell if the read was successful or not.
Are you sure your LCD is not using any pins used by the CAN-BUS Shield?
I’ve tried the buffer size both at 512 and 64 it makes no difference. I might try removing all the lcd parts in the sketch and just print on the serial connection on laptop, but I have checked all the pins on both the lcd and canbus shields and there is no conflicts but there is no harm in trying it without lcd because my end game is to send data to a nextion display.
Can someone tell me if I get this working properly will I be able to map the RPM value because I want to use the RPM figure to be displayed numerically and visually on a progress bar on a Nextion display if this wont be possible I will have to rethink my end project.
