I am sitting here with my own custom PCB which is assembled by JLCPCB. It houses an atmega328P and CH340G chip with usb socket.
I can succesfully upload programs via an arduino nano as ISP programmer.
I have succesfully tested the USB connections. I can read and send bytes from monitor to my own board over USB, so the hardware appears to be fine. Must have done something right.
Being an atmega in TQFP housing, the board settings are set to an arduino Nano. I tried UNO as well, no change in output.
Despite I can program via ICSP connector, I cannot burn the boatloader. This part of the log seems interesting.
avrdude: reading input file "0x0F"
avrdude: writing lock (1 bytes):
The whole log
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Gebruiker\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM6
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "C:\Users\Gebruiker\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3/bootloaders/optiboot/optiboot_atmega328.hex"
avrdude: writing flash (32768 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 32768 bytes of flash written
avrdude: verifying flash memory against C:\Users\Gebruiker\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3/bootloaders/optiboot/optiboot_atmega328.hex:
avrdude: load data flash data from input file C:\Users\Gebruiker\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3/bootloaders/optiboot/optiboot_atmega328.hex:
avrdude: input file C:\Users\Gebruiker\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3/bootloaders/optiboot/optiboot_atmega328.hex contains 32768 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.00s
avrdude: verifying ...
avrdude: 32768 bytes of flash verified
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x0F:
avrdude: load data lock data from input file 0x0F:
avrdude: input file 0x0F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.01s
avrdude: 1 bytes of lock verified
avrdude done. Thank you.
I am guessing that I must change something in boards.txt but I am not sure what exactly. I must confess: I have not looked into boards.txt yet either. Going to look into it now.
Can somebody tell me what precisely is happening and how can I fix this?
Kind regards,
Bas
