Windows 10 /64
Using Arduino IDE V2 rc5
AVRISP mkII
Pro mini at 3.3v
added a 1k pullup on the reset line.
The AVRISP mkii looks properly installed in the device manager.
The AVRISP shows a blinking orange the suggest a bad wire. I've checked the pretty well so I feel they are correct,'''
Any thoughts
Thanks JohnRob
Any thoughts.
Says, couldn't find usb device......
Maybe try Zadig to install correct driver.
Thanks, already tried Zadig.
UPDATE:
I tried the Zadif V2.7 loading ( if I remember correctly) the WinUSB driver. = No change from above.
I tried the DRIVER-MK2-AS-6-7-W10.zip ** = No change from above.
**This is a Windows driver for Olimex AVR-ISP-MK2 for Atmel Studio
releases.
I uninstalled everything and installed IDE V1.8.18.
Swapped out the original hex file for the optiboot hex file.
Burned bootloader with no errors.
Notes:
- With the IDE V2.0.0 RC5 the AVRISP mkII LED was blinking orange. With NO changes in wiring, with the IDE V1.8.18 the LED turned Green.
- My AVRISP mkII is an older clone.
- I verified the watchdog timer is working by creating an infinite loop with an LED blink in setup.
I get the same error when using both Arduino IDE 2.0.0-rc5 and 1.8.18 after installing the "WinUSB" driver for my "Atmel AVRISP mkII" programmer via "Zadig".
I have success with both IDE versions when I have installed the "libusbK" driver (which I always use) via "Zadig". I also have success doing the same with the "libusb-win32" driver, which is the more traditional driver for using the "Atmel AVRISP mkII" programmer with AVRDUDE (as the Arduino IDE does).
I was not able to find any condition where Arduino IDE 1.8.18 worked and Arduino IDE 2.0.0-rc5 did not. I am interested if anyone can provide me with detailed instructions for producing such conditions.
Please try this:
- Connect your "AVRISP mkII" programmer to your computer with a USB cable.
- Start "Zadig".
- From the dropdown menu, select "AVRISP mkII".
If it doesn't show up on the menu, then select Options > List all devices from the menus in Zadig and check again.
- Click the ▴ button to the right of the "Driver" selection field until you see "libusbK".
- Click the Replace Driver button.
An "Installing Driver..." dialog will now appear.
- Wait for the driver installation process to finish.
- Click the Close button in the "Driver Installation" dialog.
- Close the "Zadig" window.
Are you now able to burn the bootloader using Arduino IDE 2.0.0-rc5?
