Here is some excellent code for an ESP32 that has maintained a connection since Feb 2020:
Project, use solar cells to generate power
2/2/2020
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h"
#include "sdkconfig.h"
#include "esp_system.h"
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/timers.h"
#include "freertos/event_groups.h"
//#include "esp_sleep.h"
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
#define evtDoMQTTwd ( 1 << 1 )
EventGroupHandle_t eg; // variable for the event group handle
WiFiClient wifiClient;
PubSubClient MQTTclient(mqtt_server, mqtt_port, wifiClient);
Adafruit_BME680 bme( GPIO_NUM_5 );
This semaphore is used to stop or prevent a publish from happening during client.loop()
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_mqttOK; // protects the int mqttOK
int mqttOK = 0; // stores a count value that is used to cause an esp reset
* A single subject has been scribed to, the mqtt broker sends out "OK" messages if the client receives an OK message the mqttOK value is set back to zero
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
xSemaphoreTake( sema_mqttOK, portMAX_DELAY );
mqttOK = 0;
xSemaphoreGive( sema_mqttOK );
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
// interrupt service routine for WiFi events put into IRAM
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
switch (event) {
case SYSTEM_EVENT_STA_CONNECTED:
case SYSTEM_EVENT_STA_DISCONNECTED:
log_i("Disconnected from WiFi access point");
case SYSTEM_EVENT_AP_STADISCONNECTED:
log_i("WiFi client disconnected");
default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
sema_mqttOK = xSemaphoreCreateBinary();
eg = xEventGroupCreate(); // get an event group handle
xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 20000, NULL, 5, NULL, 1 );
xTaskCreatePinnedToCore( fDoBME, "fDoBME", 20000, NULL, 3, NULL, 1 ); // assigned to core
xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 3000, NULL, 3, NULL, 1 ); // assign all to core 1
} //void setup()
void fmqttWatchDog( void * paramater )
int maxNonMQTTresponse = 20;
for (;;)
xEventGroupWaitBits (eg, evtDoMQTTwd, pdTRUE, pdTRUE, portMAX_DELAY );
mqttOK++;
if ( mqttOK >= maxNonMQTTresponse )
ESP.restart();
vTaskDelete( NULL );
} //void fmqttWatchDog( void * paramater )
void connectToMQTT()
MQTTclient.setKeepAlive( 90 ); // needs be made before connecting
// create client ID from mac address
byte mac[5];
WiFi.macAddress(mac); // get mac address
String clientID = String(mac[0]) + String(mac[4]) ; // use mac address to create clientID
while ( !MQTTclient.connected() )
// boolean connect(const char* id, const char* user, const char* pass, const char* willTopic, uint8_t willQos, boolean willRetain, const char* willMessage);
MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password, NULL , 1, true, NULL );
vTaskDelay( 250 );
MQTTclient.setCallback( mqttCallback );
MQTTclient.subscribe( topicOK );
log_i("MQTT Connected");
} // void connectToMQTT()
void fDoBME ( void *pvParameters )
if (!bme.begin()) {
log_i("Could not find a valid BME680 sensor, check wiring!");
while (1);
// Set up oversampling and filter initialization
bme.setTemperatureOversampling(BME680_OS_8X);
bme.setHumidityOversampling(BME680_OS_2X);
bme.setPressureOversampling(BME680_OS_4X);
bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
bme.setGasHeater(320, 150); // 320*C for 150 ms
float fTemperature = 0.0f;
float fPressure = 0.0f;
float fHumidity = 0.0f;
uint32_t iGasResistance = 0;
TickType_t DelayTime = 1000 * 30;
//wait for a mqtt connection
vTaskDelay( 250 );
for ( ;; )
fTemperature = bme.readTemperature();
fTemperature = (fTemperature * 1.8f) + 32.0f; // (Celsius x 1.8) + 32
fPressure = bme.readPressure();
fPressure = fPressure / 133.3223684f; //converts to mmHg
fHumidity = bme.readHumidity();
iGasResistance = bme.readGas();
xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
log_i( "Temperature %f C, Pressure %f mmHg, Humidity %f, gasResistance %d", fTemperature, fPressure, fHumidity, iGasResistance );
MQTTclient.publish( topicOutsideTemp, String(fTemperature).c_str() );
vTaskDelay( 5 ); // gives the Raspberry Pi 4 time to receive the message and process
MQTTclient.publish( topicOutsideHumidity, String(fHumidity).c_str() );
vTaskDelay( 5 ); // no delay and RPi is still processing previous message
MQTTclient.publish( topicOutsideGasResistance, String(iGasResistance).c_str() );
vTaskDelay( 5 );
MQTTclient.publish( topicOutsidePressure, String(fPressure).c_str() );
vTaskDelay( 5 );
xSemaphoreGive( sema_MQTT_KeepAlive );
xEventGroupSetBits( eg, evtDoMQTTwd );
vTaskDelay( DelayTime );
} // for loop
vTaskDelete ( NULL );
} // void fDoBME ( void *pvParameters )
Important to not set vTaskDelay to less then 10. Errors begin to develop with the MQTT and network connection.
makes the initial wifi/mqtt connection and works to keeps those connections open.
void MQTTkeepalive( void *pvParameters )
sema_MQTT_KeepAlive = xSemaphoreCreateBinary();
xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
// setting must be set before a mqtt connection is made
MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
for (;;)
//check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
MQTTclient.loop();
else {
log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
connectToWiFi();
connectToMQTT();
vTaskDelay( 250 ); //task runs approx every 250 mS
void connectToWiFi()
int TryCount = 0;
//log_i( "connect to wifi" );
while ( WiFi.status() != WL_CONNECTED )
TryCount++;
WiFi.disconnect();
WiFi.begin( SSID, PASSWORD );
vTaskDelay( 4000 );
if ( TryCount == 10 )
ESP.restart();
WiFi.onEvent( WiFiEvent );
} // void connectToWiFi()
void loop() {}
