Cannot get images to scroll on Arduino and 8x8 matrices
I am hoping someone here can help me or point me in the right direction. I do not have a lot of experience in programming, but for the most part, I have been able to copy and paste and make the majority of my projects work, but this 8x8 matrix project is kicking my butt.
I have 4 8x8 Max72xx matrix displays hooked up together. I have tried numerous things but I cannot figure out how to get them to scroll the text. When I upload the sketch all the matrices display the exact same thing on all of them.
I believe this is the original code that I used from here
#include <LedControl.h>
const int DIN_PIN = 12;
const int CS_PIN = 10;
const int CLK_PIN = 11;
const byte IMAGES[][8] = {
  0b11111111,
  0b00000000,
  0b00000000,
  0b10000000,
  0b10000000,
  0b00000000,
  0b00000000,
  0b11111111
  0b11111111,
  0b00000000,
  0b00000000,
  0b11000000,
  0b11000000,
  0b00000000,
  0b00000000,
  0b11111111
  0b11111111,
  0b00000000,
  0b00000000,
  0b01100000,
  0b01100000,
  0b00000000,
  0b00000000,
  0b11111111
  0b11111111,
  0b00000000,
  0b00000000,
  0b00110000,
  0b00110000,
  0b00000000,
  0b00000000,
  0b11111111
  0b11111111,
  0b00000000,
  0b00000000,
  0b00011000,
  0b00011000,
  0b00000000,
  0b00000000,
  0b11111111
  0b11111111,
  0b00000000,
  0b00000000,
  0b00001100,
  0b00001100,
  0b00000000,
  0b00000000,
  0b11111111
  0b11111111,
  0b00000000,
  0b00000000,
  0b00000110,
  0b00000110,
  0b00000000,
  0b00000000,
  0b11111111
  0b11111111,
  0b00000000,
  0b00000000,
  0b00000011,
  0b00000011,
  0b00000000,
  0b00000000,
  0b11111111
  0b11111111,
  0b00000000,
  0b00000000,
  0b00000001,
  0b00000001,
  0b00000000,
  0b00000000,
  0b11111111
  0b11111111,
  0b00000000,
  0b00000000,
  0b00000011,
  0b00000011,
  0b00000000,
  0b00000000,
  0b11111111
  0b11111111,
  0b00000000,
  0b00000000,
  0b00000110,
  0b00000110,
  0b00000000,
  0b00000000,
  0b11111111
  0b11111111,
  0b00000000,
  0b00000000,
  0b00011000,
  0b00011000,
  0b00000000,
  0b00000000,
  0b11111111
  0b11111111,
  0b00000000,
  0b00000000,
  0b00110000,
  0b00110000,
  0b00000000,
  0b00000000,
  0b11111111
  0b11111111,
  0b00000000,
  0b00000000,
  0b01100000,
  0b01100000,
  0b00000000,
  0b00000000,
  0b11111111
  0b11111111,
  0b00000000,
  0b00000000,
  0b11000000,
  0b11000000,
  0b00000000,
  0b00000000,
  0b11111111
  0b11111111,
  0b00000000,
  0b00000000,
  0b10000000,
  0b10000000,
  0b00000000,
  0b00000000,
  0b11111111
const int IMAGES_LEN = sizeof(IMAGES)/8;
LedControl display = LedControl(DIN_PIN, CLK_PIN, CS_PIN);
  display.clearDisplay(0);
  display.shutdown(0, false);
  display.setIntensity(0, 5);
void displayImage(const byte* image) {
  for (int i = 0; i < 8; i++) {
    for (int j = 0; j < 8; j++) {
      display.setLed(0, i, j, bitRead(image[i], 7 - j));
int i = 0;
  displayImage(IMAGES[i]);
  if (++i >= IMAGES_LEN ) {
    i = 0;
  delay(333);
Is there a way for me to update this to take advantage of multiple matrices or am I barking up the wrong tree? I would prefer to keep this code if possible because I would like to use the matrix editor to make the animations.
Thanks in advance.
I don't know what animation you want to do, but your current code has 2 errors.
1 in this line:
you need to define how many modules you have.
If your project has 8 modules, it needs to be like this:
LedControl display = LedControl(DIN_PIN, CLK_PIN, CS_PIN, 8);
  1. This function i redo to use 8 modules:
  for (int k = 0; k < 8; k++) {
        display.setLed(k, i, j, bitRead(image[i], 7 - j));
Try your code modified:
Simulated at: https://wokwi.com/projects/396454087867262977
    0b11111111,
    0b00000000,
    0b00000000,
    0b10000000,
    0b10000000,
    0b00000000,
    0b00000000,
    0b11111111
    0b11111111,
    0b00000000,
    0b00000000,
    0b11000000,
    0b11000000,
    0b00000000,
    0b00000000,
    0b11111111
    0b11111111,
    0b00000000,
    0b00000000,
    0b01100000,
    0b01100000,
    0b00000000,
    0b00000000,
    0b11111111
    0b11111111,
    0b00000000,
    0b00000000,
    0b00110000,
    0b00110000,
    0b00000000,
    0b00000000,
    0b11111111
    0b11111111,
    0b00000000,
    0b00000000,
    0b00011000,
    0b00011000,
    0b00000000,
    0b00000000,
    0b11111111
    0b11111111,
    0b00000000,
    0b00000000,
    0b00001100,
    0b00001100,
    0b00000000,
    0b00000000,
    0b11111111
    0b11111111,
    0b00000000,
    0b00000000,
    0b00000110,
    0b00000110,
    0b00000000,
    0b00000000,
    0b11111111
    0b11111111,
    0b00000000,
    0b00000000,
    0b00000011,
    0b00000011,
    0b00000000,
    0b00000000,
    0b11111111
    0b11111111,
    0b00000000,
    0b00000000,
    0b00000001,
    0b00000001,
    0b00000000,
    0b00000000,
    0b11111111
    0b11111111,
    0b00000000,
    0b00000000,
    0b00000011,
    0b00000011,
    0b00000000,
    0b00000000,
    0b11111111
    0b11111111,
    0b00000000,
    0b00000000,
    0b00000110,
    0b00000110,
    0b00000000,
    0b00000000,
    0b11111111
    0b11111111,
    0b00000000,
    0b00000000,
    0b00011000,
    0b00011000,
    0b00000000,
    0b00000000,
    0b11111111
    0b11111111,
    0b00000000,
    0b00000000,
    0b00110000,
    0b00110000,
    0b00000000,
    0b00000000,
    0b11111111
    0b11111111,
    0b00000000,
    0b00000000,
    0b01100000,
    0b01100000,
    0b00000000,
    0b00000000,
    0b11111111
    0b11111111,
    0b00000000,
    0b00000000,
    0b11000000,
    0b11000000,
    0b00000000,
    0b00000000,
    0b11111111
    0b11111111,
    0b00000000,
    0b00000000,
    0b10000000,
    0b10000000,
    0b00000000,
    0b00000000,
    0b11111111
const int IMAGES_LEN = sizeof(IMAGES) / 8;
int i = 0;
    i = 0;
  delay(333);
The code you posted works on wokwi.com ... here is the file for setup
diagram.json
  "version": 1,
  "author": "Anonymous maker",
  "editor": "wokwi",
  "parts": [
    { "type": "wokwi-arduino-nano", "id": "nano", "top": -4.8, "left": 95.5, "attrs": {} },
      "type": "wokwi-max7219-matrix",
      "id": "matrix1",
      "top": -95.4,
      "left": -15.39,
      "attrs": { "chain": "1" }
  "connections": [
    [ "matrix1:CS", "nano:10", "green", [ "h0" ] ],
    [ "matrix1:GND", "nano:GND.1", "black", [ "h0" ] ],
    [ "nano:5V", "matrix1:V+", "red", [ "v0" ] ],
    [ "nano:12", "matrix1:DIN", "green", [ "v0" ] ],
    [ "nano:11", "matrix1:CLK", "green", [ "v0" ] ]
  "dependencies": {}
dot
p.s. Your 11th matrix is missing. I filled it in here.
