Hello guys..
I have a small project includes connection between fingerprint reader and gsm module so in status of not-matched fingerprint the gsm sends a message to a person warns him like a type of security feature.
My code is here:
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
SoftwareSerial GPRS(11, 10); // RX, TX
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
GPRS.begin(9600);
// Set as appropriate for your case
GPRS.println("AT+CMGF=1");
for (int i = 1; i <= 15; i++) {
GPRS.print("AT+CMGD=");
GPRS.println(i);
delay(200);
// Not really necessary but prevents the serial monitor from dropping any input
while (GPRS.available())
Serial.write(GPRS.read());
while (!Serial); // For Yun/Leo/Micro/Zero/...
delay(100);
Serial.println("\n\nAdafruit finger detect test");
// set the data rate for the sensor serial port
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor :(");
while (1) { delay(1); }
finger.getTemplateCount();
Serial.print("Sensor contains "); Serial.print(finger.templateCount); Serial.println(" templates");
Serial.println("Waiting for valid finger...");
void loop() // run over and over again
getFingerprintIDez();
delay(50); //don't ned to run this at full speed.
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
Serial.println("No finger detected");
return p;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
return p;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
return p;
default:
Serial.println("Unknown error");
return p;
// OK success!
p = finger.image2Tz();
switch (p) {
Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
// OK converted!
p = finger.fingerFastSearch();
if (p == FINGERPRINT_OK) {
Serial.println("Found a print match!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
Serial.println("Did not find a match");
return p;
return p;
// found a match!
Serial.print("Found ID #"); Serial.print(finger.fingerID);
Serial.print(" with confidence of "); Serial.println(finger.confidence);
return finger.fingerID;
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
// found a match!
if(finger.fingerID == 1){
Serial.println("OKKK");
else if(finger.fingerID == 2){
Serial.println("HEEEE");
else{
sendSMS();
delay(2000);
void sendSMS() {
GPRS.println("AT+CMGS=\"+9647705707666\"");
delay(100); //
GPRS.print("Some one opened the door!");
GPRS.write( 0x1a ); // ctrl+Z character
Serial.println("Some one opened the door!");
There is a section in the code deals with the fingerprint which not matched with those were enrolled but it seems that it's don't success to do that.
If you see in the code there is:
return p;
return p;
return p;
In status of putting my finger that doesn't enrolled (The Serial moniter don't show anything just the light of fingerprint reader stills blink slowly as reading my finger and no response) ASAP i putting my finger which already enrolled the serial moniter response that is matched!
Any one can help?
