Problem associated with interfacing Arduino UNO with R307S and GSM800L
Please anybody here can solve my problem associated with my Fingerprint Sensor R307S? Whenever I tried to Interface R307S separately it works fine for code given by Adafruit Fingerprint Sensor Library to enroll and fingerprint sketch. But it doesn't work for ChangePassword sketch(provided by Adafruit Fingerprint Sensor Library). The serial Monitor says Fingerprint Not Found. and also it says same when I use GSM800L AND R307S interfaced with Arduino UNO. The arduino is not sensing my fingerprint for above two situation. How can I fix my problem? Here are the codes I used:
1. Enroll code:
  This is an example sketch for our optical Fingerprint sensor
  Designed specifically to work with the Adafruit BMP085 Breakout
  ----> http://www.adafruit.com/products/751
  These displays use TTL Serial to communicate, 2 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  Small bug-fix by Michael cochez
  BSD license, all text above must be included in any redistribution
#include <Adafruit_Fingerprint.h>
#if (defined(__AVR__) || defined(ESP8266)) && !defined(__AVR_ATmega2560__)
// For UNO and others without hardware serial, we must use software serial...
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino  (WHITE wire)
// Set up the serial port to use softwareserial..
SoftwareSerial mySerial(2, 3);
#else
// On Leonardo/M0/etc, others with hardware serial, use hardware serial!
// #0 is green wire, #1 is white
#define mySerial Serial1
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
uint8_t id;
  while (!Serial);  // For Yun/Leo/Micro/Zero/...
  delay(100);
  Serial.println("\n\nAdafruit Fingerprint sensor enrollment");
  // set the data rate for the sensor serial port
  finger.begin(57600);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
    Serial.println("Did not find fingerprint sensor :(");
    while (1) { delay(1); }
  Serial.println(F("Reading sensor parameters"));
  finger.getParameters();
  Serial.print(F("Status: 0x")); Serial.println(finger.status_reg, HEX);
  Serial.print(F("Sys ID: 0x")); Serial.println(finger.system_id, HEX);
  Serial.print(F("Capacity: ")); Serial.println(finger.capacity);
  Serial.print(F("Security level: ")); Serial.println(finger.security_level);
  Serial.print(F("Device address: ")); Serial.println(finger.device_addr, HEX);
  Serial.print(F("Packet len: ")); Serial.println(finger.packet_len);
  Serial.print(F("Baud rate: ")); Serial.println(finger.baud_rate);
uint8_t readnumber(void) {
  uint8_t num = 0;
  while (num == 0) {
    while (! Serial.available());
    num = Serial.parseInt();
  return num;
void loop()                     // run over and over again
  Serial.println("Ready to enroll a fingerprint!");
  Serial.println("Please type in the ID # (from 1 to 127) you want to save this finger as...");
  id = readnumber();
  if (id == 0) {// ID #0 not allowed, try again!
     return;
  Serial.print("Enrolling ID #");
  Serial.println(id);
  while (! getFingerprintEnroll() );
uint8_t getFingerprintEnroll() {
  int p = -1;
  Serial.print("Waiting for valid finger to enroll as #"); Serial.println(id);
  while (p != FINGERPRINT_OK) {
    p = finger.getImage();
    switch (p) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
    case FINGERPRINT_NOFINGER:
      Serial.print(".");
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
    default:
      Serial.println("Unknown error");
  // OK success!
  p = finger.image2Tz(1);
  switch (p) {
      Serial.println("Image converted");
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
      return p;
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      return p;
    default:
      return p;
  Serial.println("Remove finger");
  delay(2000);
  p = 0;
  while (p != FINGERPRINT_NOFINGER) {
  Serial.print("ID "); Serial.println(id);
  p = -1;
  Serial.println("Place same finger again");
    switch (p) {
      Serial.print(".");
    default:
  // OK success!
  p = finger.image2Tz(2);
  switch (p) {
      return p;
      return p;
      return p;
      return p;
    default:
      return p;
  // OK converted!
  Serial.print("Creating model for #");  Serial.println(id);
  p = finger.createModel();
  if (p == FINGERPRINT_OK) {
    Serial.println("Prints matched!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_ENROLLMISMATCH) {
    Serial.println("Fingerprints did not match");
    return p;
    return p;
  p = finger.storeModel(id);
    Serial.println("Stored!");
    return p;
  } else if (p == FINGERPRINT_BADLOCATION) {
    Serial.println("Could not store in that location");
    return p;
  } else if (p == FINGERPRINT_FLASHERR) {
    Serial.println("Error writing to flash");
    return p;
    return p;
  return true;
2.Fingerprint Code(to take attendance):
/****`Use code tags to format code for the forum`***********************************************
  interface
#else
#endif
  delay(100);
  Serial.println("\n\nAdafruit finger detect test");
  delay(5);
  finger.getTemplateCount();
  if (finger.templateCount == 0) {
    Serial.print("Sensor doesn't contain any fingerprint data. Please run the 'enroll' example.");
  else {
    Serial.println("Waiting for valid finger...");
      Serial.print("Sensor contains "); Serial.print(finger.templateCount); Serial.println(" templates");
  getFingerprintID();
  delay(50);            //don't ned to run this at full speed.
uint8_t getFingerprintID() {
  uint8_t p = finger.getImage();
  switch (p) {
      Serial.println("No finger detected");
      return p;
      return p;
      return p;
    default:
      return p;
  // OK success!
  p = finger.image2Tz();
  switch (p) {
      return p;
      return p;
      return p;
      return p;
    default:
      return p;
  // OK converted!
  p = finger.fingerSearch();
    Serial.println("Found a print match!");
    return p;
  } else if (p == FINGERPRINT_NOTFOUND) {
    Serial.println("Did not find a match");
    return p;
    return p;
  // found a match!
  Serial.print("Found ID #"); Serial.print(finger.fingerID);
  Serial.print(" with confidence of "); Serial.println(finger.confidence);
  return finger.fingerID;
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
  if (p != FINGERPRINT_OK)  return -1;
  p = finger.fingerFastSearch();
  // found a match!
3.Change Password code:
#include <SoftwareSerial.h>
SoftwareSerial fingerprintSerial(2, 3);  // RX, TX for fingerprint sensor
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&fingerprintSerial);
  delay(100);
  // Change the password to your desired value
  uint32_t new_password = 12345; // Change this to your desired password
  finger.setPassword(new_password);
  Serial.println("Password changed successfully!");
  // Your main loop code goes here
  1. This is the code provided by chatgpt to interface R307S and GSM800L with Arduino Uno ::
SoftwareSerial gsmSerial(7, 8);            // RX, TX for GSM module
String phoneNumber = "9975783632";
String message = "Attendance recorded.";
  fingerprintSerial.begin(9600);
  gsmSerial.begin(9600);
  if (!finger.verifyPassword()) {
    Serial.println("Couldn't find fingerprint sensor :(");
    while (1);
  if (scanFingerprint()) {
    logAttendance();
    sendSMS();
    delay(5000); // Delay to avoid multiple scans in a short time
bool scanFingerprint() {
  Serial.println("Place your finger on the sensor...");
      Serial.println("Template created");
      return true;  // Fingerprint recognized
      Serial.println("Failed to create template");
    Serial.println("Failed to capture image");
  return false;  // Fingerprint not recognized
void logAttendance() {
  Serial.println("Attendance recorded!");
  // Implement the necessary functions to log attendance
  // You can store attendance data in a variable, a file, a database, or any other desired location
void sendSMS() {
  Serial.println("Sending SMS...");
  gsmSerial.println("AT+CMGF=1");  // Set SMS mode to text
  gsmSerial.print("AT+CMGS=\"");
  gsmSerial.print(phoneNumber);
  gsmSerial.println("\"");
  gsmSerial.println(message);
  gsmSerial.println((char)26);  // End of message character
  Serial.println("SMS Sent!");
  // You may want to add error handling for the SMS sending process
  // Check the GSM module documentation for additional commands and possible responses
I also checked wirings and supply to the board and to the GSM800L. Everything is fine. So what shall I do now?
I am curious why if 'finger' is initialized to 57600 baud in examples 1,2 an 3, but 'fingerprintSerial' in example 4 is initialized to 9600 baud? If the fingerprint reader runs at 57600, then perhaps:
should read:
fingerprintSerial.begin(57600);
Thank You for your reply. This is the code I had taken from Chatgpt but then afterwards I also tried by changing baudrate to 57600 but still can't sensed by arduino. Now what can be the possible reasons?
