I don't know why it happens but it looks like retrying solves the issue. I've just upgrade my yun using the latest zip file and indeed the first run was UNsuccessful whether the second one succeeded
root@Arduino:~# opkg update
Downloading http://downloads.arduino.cc/openwrtyun/1/packages/Packages.gz.
Updated list of available packages in /var/opkg-lists/attitude_adjustment.
Downloading http://downloads.arduino.cc/openwrtyun/1/packages/Packages.sig.
Signature check failed.
Remove wrong Signature file.
Signature check passed.
Can you send me an email with the following files attached ?
/etc/opkg/secring.gpg
/etc/opkg/trustdb.gpg
/etc/opkg/trusted.gpg
Address is f.fissore@arduino.cc
No problem, just a question. How did you do that? Using the webpanel? Or manually? My suspect is that your yun was still using the gpg keys of linino while it was downloading from arduino.cc
I upgraded by placing the new Arduino image on the SD card and then logged into the http://arduino.local webpage and it asked me if I wanted to update the system.
I've got the same error with the actual Wrt image.
first in the admin panel under software first it showed many mb free memory after a reset it went down to 132kb.
and I can't see many packages I had installed before...
whats going on?
ooh I see. It's the try to install node that is messing up everything.
UPDATE:
okay I could install node from the shell but I only have 268.00 KB free space left afterwards and cant install package node-socket.io
is that correct?
