Using the 3.7.4 version of ESPAsyncWebServer I get an exception when I try to read the url() from a request lambda.
Here a complete MRE:
#include <WiFi.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
AsyncWebServer server(80);
WiFi.begin("MySSID", "MyPassword");
Serial.println("Connecting to WiFi...");
Serial.println("Connected to WiFi");
server.onNotFound([](AsyncWebServerRequest *request) {
if (request) Serial.println(request->url());
else Serial.println("not valid");
request->send(404);
server.begin();
Here the full debug output:
Connected to WiFi
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x400f20b4 PS : 0x00060233 A0 : 0x800ea2e2 A1 : 0x3ffd0f30
A2 : 0x3ffbdeb8 A3 : 0x000b9033 A4 : 0x000b9033 A5 : 0x3ffd0f6c
A6 : 0x00060220 A7 : 0x00000001 A8 : 0x00000000 A9 : 0x0000002f
A10 : 0x60000000 A11 : 0x3ff40000 A12 : 0x00060220 A13 : 0x00060223
A14 : 0x007bdebc A15 : 0x003fffff SAR : 0x00000008 EXCCAUSE: 0x0000001c
EXCVADDR: 0x000b9033 LBEG : 0x40089aed LEND : 0x40089b0f LCOUNT : 0xffffffff
Backtrace: 0x400f20b1:0x3ffd0f30 0x400ea2df:0x3ffd0f60 0x400eb1a0:0x3ffd0f90 0x400eb965:0x3ffd0fe0 0x400e82bd:0x3ffd1010 0x400e5b19:0x3ffd1030 0x400e60cd:0x3ffd1050 0x400d27f3:0x3ffd1070 0x400d5ea5:0x3ffd10b0 0x40183697:0x3ffd1100 0x400d5652:0x3ffd1120 0x400e09a3:0x3ffd11b0 0x400d5652:0x3ffd11f0 0x400e2086:0x3ffd1280 0x400e2c7e:0x3ffd12c0 0x400e2dc7:0x3ffd1300 0x400e2fed:0x3ffd1350 0x400d37e4:0x3ffd1370 0x400d3a95:0x3ffd13c0
#0 0x400f20b1 in uart_hal_write_txfifo at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/hal/uart_hal_iram.c:41
#1 0x400ea2df in uart_enable_tx_write_fifo at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/driver/uart.c:833
#2 0x400eb1a0 in uart_tx_all at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/driver/uart.c:1256
#3 0x400eb965 in uart_tx_all at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/driver/uart.c:1225
(inlined by) uart_write_bytes at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/driver/uart.c:1284
#4 0x400e82bd in uartWriteBuf at /home/user/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal-uart.c:682
#5 0x400e5b19 in HardwareSerial::write(unsigned char const*, unsigned int) at /home/user/.platformio/packages/framework-arduinoespressif32/cores/esp32/HardwareSerial.cpp:480
#6 0x400e60cd in Print::write(char const*, unsigned int) at /home/user/.platformio/packages/framework-arduinoespressif32/cores/esp32/Print.h:72
(inlined by) Print::print(String const&) at /home/user/.platformio/packages/framework-arduinoespressif32/cores/esp32/Print.cpp:79
(inlined by) Print::println(String const&) at /home/user/.platformio/packages/framework-arduinoespressif32/cores/esp32/Print.cpp:176
#7 0x400d27f3 in std::_Function_handler<void (AsyncWebServerRequest*), setup()::{lambda(AsyncWebServerRequest*)#1}>::_M_invoke(std::_Any_data const&, AsyncWebServerRequest*&&) at src/main.cpp:22
(inlined by) _M_invoke at /home/user/.platformio/packages/toolchain-xtensa-esp32@8.4.0+2021r2-patch5/xtensa-esp32-elf/include/c++/8.4.0/bits/std_function.h:297
#8 0x400d5ea5 in std::function<void (AsyncWebServerRequest*)>::operator()(AsyncWebServerRequest*) const at /home/user/.platformio/packages/toolchain-xtensa-esp32@8.4.0+2021r2-patch5/xtensa-esp32-elf/include/c++/8.4.0/bits/std_function.h:687
(inlined by) AsyncCallbackWebHandler::handleRequest(AsyncWebServerRequest*) at .pio/libdeps/Aphrodite/ESPAsyncWebServer/src/WebHandlers.cpp:311
#9 0x40183697 in std::_Function_handler<void (), AsyncWebServerRequest::_runMiddlewareChain()::{lambda()#2}::operator()() const::{lambda()#1}>::_M_invoke(std::_Any_data const&) at WebRequest.cpp:?
#10 0x400d5652 in std::function<void ()>::operator()() const at /home/user/.platformio/packages/toolchain-xtensa-esp32@8.4.0+2021r2-patch5/xtensa-esp32-elf/include/c++/8.4.0/bits/std_function.h:687
(inlined by) AsyncMiddlewareChain::_runChain(AsyncWebServerRequest*, std::function<void ()>) at .pio/libdeps/Aphrodite/ESPAsyncWebServer/src/Middleware.cpp:56
#11 0x400e09a3 in std::_Function_handler<void (), AsyncWebServerRequest::_runMiddlewareChain()::{lambda()#2}>::_M_invoke(std::_Any_data const&) at .pio/libdeps/Aphrodite/ESPAsyncWebServer/src/WebRequest.cpp:700
#12 0x400d5652 in std::function<void ()>::operator()() const at /home/user/.platformio/packages/toolchain-xtensa-esp32@8.4.0+2021r2-patch5/xtensa-esp32-elf/include/c++/8.4.0/bits/std_function.h:687
#13 0x400e2086 in AsyncWebServerRequest::_runMiddlewareChain() at .pio/libdeps/Aphrodite/ESPAsyncWebServer/src/WebRequest.cpp:698 (discriminator 4)
#14 0x400e2c7e in AsyncWebServerRequest::_parseLine() at .pio/libdeps/Aphrodite/ESPAsyncWebServer/src/WebRequest.cpp:683
#15 0x400e2dc7 in AsyncWebServerRequest::_onData(void*, unsigned int) at .pio/libdeps/Aphrodite/ESPAsyncWebServer/src/WebRequest.cpp:158
#16 0x400e2fed in std::_Function_handler<void (void*, AsyncClient*, void*, unsigned int), AsyncWebServerRequest::AsyncWebServerRequest(AsyncWebServer*, AsyncClient*)::{lambda(void*, AsyncClient*, void*, unsigned int)#5}>::_M_invoke(std::_Any_data const&, void*&&, AsyncClient*&&, std::_Any_data const&, unsigned int&&) at .pio/libdeps/Aphrodite/ESPAsyncWebServer/src/WebRequest.cpp:70
#17 0x400d37e4 in std::function<void (void*, AsyncClient*, void*, unsigned int)>::operator()(void*, AsyncClient*, void*, unsigned int) const at /home/user/.platformio/packages/toolchain-xtensa-esp32@8.4.0+2021r2-patch5/xtensa-esp32-elf/include/c++/8.4.0/bits/std_function.h:687
(inlined by) AsyncClient::_recv(tcp_pcb*, pbuf*, signed char) at .pio/libdeps/Aphrodite/AsyncTCP/src/AsyncTCP.cpp:1123
#18 0x400d3a95 in AsyncClient::_s_recv(void*, tcp_pcb*, pbuf*, signed char) at .pio/libdeps/Aphrodite/AsyncTCP/src/AsyncTCP.cpp:1488
(inlined by) _handle_async_event at .pio/libdeps/Aphrodite/AsyncTCP/src/AsyncTCP.cpp:257
(inlined by) _async_service_task at .pio/libdeps/Aphrodite/AsyncTCP/src/AsyncTCP.cpp:292
I also tried to:
- print
request->url().c_str() - store the
request->url()in a String variable before printing it
in any case the exception is raised at the line that contains request->url().
What am I missing?
