I am trying to send gas sensor values from RAK 4631 to T-Beam through LoraP2P. RAK 4631 uses the SX126x-RAK4630 Library for Lora and the T-Beam uses LoRa by sandeep mistry for Lora. I cannot seem to receive the data from the receiver.
#include <Adafruit_TinyUSB.h>
#include <SX126x-RAK4630.h>
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Wire.h>
#include "ADC121C021.h"
//defining the functions for reading the gas sensor values
#define EN_PIN WB_IO6 //Logic high enables the device. Logic low disables the device
#define ALERT_PIN WB_IO5 //a high indicates that the respective limit has been violated.
#define MQ2_ADDRESS 0x51 //the device i2c address
#define RatioMQ2CleanAir (1.0) //RS / R0 = 1.0 ppm
#define MQ2_RL (10.0) //the board RL = 10KΩ can adjust
//defining the parameters for the lora peer to peer communication
// Define LoRa parameters
#define RF_FREQUENCY 923000000 // Hz
#define TX_OUTPUT_POWER 22 // dBm
#define LORA_BANDWIDTH 0 // [0: 125 kHz, 1: 250 kHz, 2: 500 kHz, 3: Reserved]
#define LORA_SPREADING_FACTOR 7 // [SF7..SF12]
#define LORA_CODINGRATE 1 // [1: 4/5, 2: 4/6, 3: 4/7, 4: 4/8]
#define LORA_PREAMBLE_LENGTH 8 // Same for Tx and Rx
#define LORA_SYMBOL_TIMEOUT 0 // Symbols
#define LORA_FIX_LENGTH_PAYLOAD_ON false
#define LORA_IQ_INVERSION_ON false
#define RX_TIMEOUT_VALUE 5000 //changed from original value of 3000
#define TX_TIMEOUT_VALUE 5000 //changed from original value of 3000
//Lora function declarations
void OnTxDone(void);
void OnTxTimeout(void);
#ifdef NRF52_SERIES
#define LED_BUILTIN 35
#endif
//for mq2 sensor
ADC121C021 MQ2;
//for lorawan sensor
static RadioEvents_t RadioEvents;
static uint8_t TxdBuffer[64];
//mq2 sensor start
pinMode(ALERT_PIN, INPUT);
pinMode(EN_PIN, OUTPUT);
digitalWrite(EN_PIN, HIGH); //power on RAK12004
delay(5);
//initialize the lora chip
lora_rak4630_init();
time_t timeout = millis();
while (!Serial)
delay(100); //delaying for 100 milliseconds indefinitely
//********ADC121C021 ADC convert init ********************************
while (!(MQ2.begin(MQ2_ADDRESS, Wire)))
Serial.println("please check device!!!");
delay(200);
Serial.println("MQ2 gas sensor seems to be working fine");
//testing the lora p2p test
Serial.println("============");
Serial.println("Lorap2p Tx Test");
Serial.println("=========");
//Initialize radio call backs
RadioEvents.TxDone = OnTxDone;
RadioEvents.RxDone = NULL; //since this is for transmission
RadioEvents.TxTimeout = OnTxTimeout;
RadioEvents.RxTimeout = NULL;
RadioEvents.RxError = NULL;
//Initialize the radio
Radio.Init(&RadioEvents);
//Set the radio channel
Radio.SetChannel(RF_FREQUENCY);
//Set Radio Tx configuration
Radio.SetTxConfig(MODEM_LORA, TX_OUTPUT_POWER, 0 , LORA_BANDWIDTH, LORA_SPREADING_FACTOR, LORA_CODINGRATE, LORA_PREAMBLE_LENGTH, LORA_FIX_LENGTH_PAYLOAD_ON, true, 0, 0, LORA_IQ_INVERSION_ON, TX_TIMEOUT_VALUE);
//send();
delay(3000);
//sending some data to establish connection
//**************init MQ2 *****************************************************
MQ2.setRL(MQ2_RL);
*detect Propane gas if to detect other gas need to reset A and B value,it depend on MQ sensor datasheet
MQ2.setA(-0.890); //A -> Slope, -0.685
MQ2.setB(1.125); //B -> Intersect with X - Axis 1.019
//Set math model to calculate the PPM concentration and the value of constants
MQ2.setRegressionMethod(0); //PPM = pow(10, (log10(ratio)-B)/A)
float calcR0 = 0;
for (int i = 1; i <= 100; i++)
calcR0 += MQ2.calibrateR0(RatioMQ2CleanAir);
MQ2.setR0(calcR0 / 10);
if (isinf(calcR0))
Serial.println("Warning: Conection issue founded, R0 is infite (Open circuit detected) please check your wiring and supply");
while (1)
if (calcR0 == 0)
Serial.println("Warning: Conection issue founded, R0 is zero (Analog pin with short circuit to ground) please check your wiring and supply");
while (1)
float r0 = MQ2.getR0();
Serial.printf("R0 Value is:%3.2f\r\n", r0);
float sensorPPM;
float PPMpercentage;
float tempPPM; //need to fix this part
//handle radio events
Radio.IrqProcess();
Serial.println("Getting Conversion Readings from ADC121C021");
Serial.println(" ");
sensorPPM = MQ2.readSensor();
tempPPM = sensorPPM; //no need to fix this variable
Serial.printf("sensor PPM Value is: %3.4f\r\n", sensorPPM);
PPMpercentage = sensorPPM / 10000;
sensorPPM = (round(tempPPM*100));
sensorPPM = sensorPPM/100;
Serial.printf ("The new rounded value of sensorPPM is %3.4f\r\n ", sensorPPM); //to test the value of the new rounded file
Serial.printf("PPM percentage Value is:%3.2f%%\r\n", PPMpercentage);
Serial.println(" *************************** ");
int intPart = (int)sensorPPM;
float decPart = sensorPPM - (float)intPart;
if (sensorPPM >= 1000 ){
int temp = intPart;
uint8_t ppmbuf[7];
for (int i=3 ; i >=0 ; i--){
ppmbuf[i] = temp % 10;
temp /= 10;
ppmbuf[4] = 0;
ppmbuf[5] = (int)(decPart *100) / 10 ;
ppmbuf[6] = (int)(decPart *100) % 10;
Radio.Send(ppmbuf, 7);
//tesing lines
Serial.println("The contents of the packet are :");
for (int j=0 ; j <=6 ; j++){
const char buffer = (char)ppmbuf[j];
Serial.println(ppmbuf[j]);
else {
uint8_t ppmbuf[6];
int temp = intPart;
for (int i=2 ; i >= 0 ; i--){
temp = temp / 10;
ppmbuf[3] = 0;
ppmbuf[4] = (int)(decPart *100) / 10;
ppmbuf[5] = (int)(decPart *100) % 10;
Radio.Send(ppmbuf, 6);
//tesing lines
for (int j=0 ; j <=5 ; j++){
delay(60000);
Serial.printf("The delay partt of the function has been reached");
//yielld();
void OnTxDone(void){
Serial.println("onTxDone");
delay(15000);
//send();
Serial.println("OnTxTimeout");
The Lora Receiver code is as below
#include <SPI.h>
#include <Wire.h>
#include <LoRa.h>
//#include "Adafruit_SSD1306.h"
#define SCK 5 // GPIO5 -- SX1278's SCK
#define MISO 19 // GPIO19 -- SX1278's MISO
#define MOSI 27 // GPIO27 -- SX1278's MOSI
#define SS 18 // GPIO18 -- SX1278's CS
#define RST 23 // GPIO14 -- SX1278's RESET
#define DI0 26 // GPIO26 -- SX1278's IRQ(Interrupt Request)
#define BAND 923E6
// //defining OLED pins
// #define OLED_SDA 21
// #define OLED_SCL 22
// #define SCREEN_WIDTH 128
// #define SCREEN_HEIGHT 64
//creating OLED display object
//Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire);
String LoraData;
String rssi = "RSSI --";
String packSize = "--";
String packet ;
//to display data on the lora screen
// void loraData(){
// display.clearDisplay();
// //display.setTextAlignment(TEXT_ALIGN_LEFT);
// display.setTextColor(WHITE);
// display.setCursor(0,0);
// display.println("Received "+ packSize + " bytes");
// display.display();
// delay(2000);
// display.println("Packet is "+ packet);
// delay(2000);
// //display.drawStringMaxWidth(0 , 26 , 128, packet);
// //display.drawString(0, 0, rssi);
// display.println("RSSI is "+ rssi);
// delay(2000);
//function is called when the data has been received
// void cbk(int packetSize) {
// packet ="";
// packSize = String(packetSize,DEC);
// for (int i = 0; i < packetSize; i++) { packet += (char) LoRa.read(); }
// rssi = "RSSI " + String(LoRa.packetRssi(), DEC) ;
// loraData();
//pinMode(16, INPUT);
//digitalWrite(16, LOW);
//delay(50);
//digitalWrite(16, HIGH);
while (!Serial)
//Wire.begin(OLED_SDA, OLED_SCL);
// if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3c, false, false)){
// Serial.println("SSD1306 allocation failed");
Serial.println("Lora Receiver Callback");
SPI.begin(SCK,MISO,MOSI,DI0);
LoRa.setPins(SS,RST,DI0);
LoRa.setSpreadingFactor(7);
LoRa.setSignalBandwidth(125000);
LoRa.setCodingRate4(1);
LoRa.setPreambleLength(8);
if(!LoRa.begin(BAND)){
Serial.println("Starting Lora failed!");
while(1);
//Lora signal has been received
LoRa.receive();
Serial.println("init ok");
//display.begin();
//display.flipScreenVertically();
delay(1500);
int packetSize = LoRa.parsePacket();
Serial.printf("The tbeam has entered the loop cycle\n");
if (packetSize) {
//received a packet
//read packet
while(LoRa.available()){
LoraData = LoRa.readString();
Serial.print(LoraData);
//print rssi of packet
int rssi = LoRa.packetRssi();
Serial.println(" with RSSI");
Serial.println(rssi);
delay(10000);
On the serial monitor for the transmitter, it displays the sensor values and TxDone. On the receiver end, I can see that LoRa has started yet the device doesn't receive any values.
