Cannot send commands from android terminal via Bluetooth module (HC-05)
Hello. I am trying to send commands in terminal to an Arduino Uno connected to my phone via a bluetooth HC-05 module. My phone finds the module and connects successfully.
I tried running the code below, to turn led on when pressing 'a' and turn off for 'b', but when sending input from my phone terminal the led does not respond. (Commands in the serial monitor work fine.)
Arduino Turn LED On/Off using Serial Commands
Created April 22, 2015
Hammad Tariq, Incubator (Pakistan)
It's a simple sketch which waits for a character on serial
and in case of a desirable character, it turns an LED on/off.
Possible string values:
a (to turn the LED on)
b (tor turn the LED off)
char junk;
String inputString="";
void setup() // run once, when the sketch starts
Serial.begin(9600); // set the baud rate to 9600, same should be of your Serial Monitor
pinMode(13, OUTPUT);
if(Serial.available()){
while(Serial.available())
char inChar = (char)Serial.read(); //read the input
inputString += inChar; //make a string of the characters coming on serial
Serial.println(inputString);
while (Serial.available() > 0)
{ junk = Serial.read() ; } // clear the serial buffer
if(inputString == "a"){ //in case of 'a' turn the LED on
digitalWrite(13, HIGH);
}else if(inputString == "b"){ //incase of 'b' turn the LED off
digitalWrite(13, LOW);
inputString = "";
