Cannot understand how DS3231 alarm Work
Hi, i'm trying get the RTC DS3231 on a Arduino mega send interrupts to arduino.
But i not understand how it sends. to debug i connect a LED also tho the interrupt pin of DS3231 to have an idea of the signal, i get something like this
AS
---------------_____________
AS means when the alarm is set (::20) every 20 seconds, my surprise is that works fine for the first time. Then it keeps some time HIGH, and goes down forever.
Here is the code
#include <Wire.h>
#include <DS3231.h>
#include <avr/sleep.h>
#include "DHT.h"
#define WAKE_PIN 2                   // pin used for waking up
#define DHTPIN 3     // what pin we're connected to
#define DHTTYPE DHT22   // DHT 22  (AM2302)
int led=13;
DS3231 clock;
RTCDateTime dt;
DHT dht(DHTPIN, DHTTYPE);
bool on= false;
bool onwake=false;
  // Initialize DS3231
  Serial.println("Initialize DS3231");
  delay(100);
  clock.begin();
  clock.enableOutput(false);
  pinMode(WAKE_PIN, INPUT_PULLUP);
  pinMode(led, OUTPUT);
  // Disarm alarms and clear alarms for this example, because alarms is battery backed.
  // Under normal conditions, the settings should be reset after power and restart microcontroller.
  clock.armAlarm1(false);
  clock.clearAlarm1();
  // Set Alarm1 - Every 20s in each minute
  // setAlarm1(Date or Day, Hour, Minute, Second, Mode, Armed = true)
  clock.setAlarm1(0, 0, 0, 20, DS3231_MATCH_S);
  attachInterrupt(digitalPinToInterrupt(WAKE_PIN), wakeUpNow, CHANGE);
  // Check alarm settings
  checkAlarms();
void checkAlarms()
  RTCAlarmTime a1;
  RTCAlarmTime a2;
  if (clock.isArmed1())
    a1 = clock.getAlarm1();
    Serial.print("Alarm1 is triggered ");
    switch (clock.getAlarmType1())
      case DS3231_MATCH_S:
        Serial.print("when seconds match: ");
        Serial.println(clock.dateFormat("__ __:__:s", a1));
        delay(100);
        default:
        Serial.println("UNKNOWN RULE");
void toDoOnAlarm(){
  on=true;
void wakeUpNow() {
  noInterrupts();
  if(!onwake){
    onwake=1;
  // execute code here after wake-up before returning to the loop() function
  // timers and code using timers (serial.print and more...) will not work here.
  // we don't really need to execute any special functions here, since we
  // just want the thing to wake up
    Serial.println("Woke up");
    toDoOnAlarm();
    delay(100);
    onwake=0;
  interrupts();
void sleepNow() {
    set_sleep_mode(SLEEP_MODE_PWR_DOWN);    // sleep mode is set here
    sleep_enable();                         // enables the sleep bit in the mcucr register
    attachInterrupt(digitalPinToInterrupt(WAKE_PIN),wakeUpNow, CHANGE);  // use interrupt 0 (pin 2) and run function
    sleep_mode();                           // here the device is actually put to sleep!!
    // THE PROGRAM CONTINUES FROM HERE AFTER WAKING UP
    sleep_disable();         // first thing after waking from sleep: disable sleep...
    detachInterrupt(digitalPinToInterrupt(WAKE_PIN));      // disables interrupt 0 on pin 2 so the wakeUpNow code will not be executed during normal running time.
  dt = clock.getDateTime();
  if(on){
    Serial.println("ON");
    Serial.println(clock.dateFormat("d-m-Y H:i:s - l", dt));
    float t = clock.readTemperature();
    float t2 = dht.readTemperature();
    Serial.print("T: ");
    Serial.println(t);
    Serial.print("T2: ");
    Serial.println(t2);
    delay(100);
  else{
    Serial.println("OFF");
    Serial.println(t);
    Serial.println(t2);
    delay(100);
  // Call isAlarm1(false) if you want clear alarm1 flag manualy by clearAlarm1();
  if (clock.isAlarm1())
    Serial.println("ALARM 1 TRIGGERED!");
    digitalWrite(led, HIGH);
    digitalWrite(led, LOW);
    Serial.println("Entering sleep");
    delay(100); // sleep function called here
    sleepNow();
 delay(900);
