Hey, thanks or reaching out. I did have a bunch of pics attached but the forum said I can only post one because I'm new. Yes, I'm trying to upload via the ISCP pins. The MCU on the board says it's a ATMEL TINY13A. I'll attach as much as I can. Here's the entire error message:
Arduino: 1.8.19 (Windows 10), Board: "ATtiny13, 1.2 MHz internal osc., EEPROM retained, BOD 1.8V, Micros enabled"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Owner\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Owner\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Owner\Documents\Arduino\libraries -fqbn=MicroCore:avr:13:clock=1M2,eeprom=keep,BOD=1v8,timing=micros_enabled -vid-pid=0403_6001 -ide-version=10819 -build-path C:\Users\Owner\AppData\Local\Temp\arduino_build_346904 -warnings=none -build-cache C:\Users\Owner\AppData\Local\Temp\arduino_cache_396358 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18 -prefs=runtime.tools.avrdude-6.3.0-arduino18.path=C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose C:\Users\Owner\Desktop\Firefly\olesiaserba-attachments\olesiaserba-attachments\Fireflies2\Fireflies2.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Owner\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Owner\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Owner\Documents\Arduino\libraries -fqbn=MicroCore:avr:13:clock=1M2,eeprom=keep,BOD=1v8,timing=micros_enabled -vid-pid=0403_6001 -ide-version=10819 -build-path C:\Users\Owner\AppData\Local\Temp\arduino_build_346904 -warnings=none -build-cache C:\Users\Owner\AppData\Local\Temp\arduino_cache_396358 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18 -prefs=runtime.tools.avrdude-6.3.0-arduino18.path=C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose C:\Users\Owner\Desktop\Firefly\olesiaserba-attachments\olesiaserba-attachments\Fireflies2\Fireflies2.ino
Using board '13' from platform in folder: C:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0
Using core 'microcore' from platform in folder: C:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0
Detecting libraries used...
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=attiny13a -DF_CPU=1200000L -DARDUINO=10819 -DARDUINO_attiny -DARDUINO_ARCH_AVR -Wextra -flto -g -DENABLE_MICROS "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\variants\attiny13" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\sketch\Fireflies2.ino.cpp" -o nul
Generating function prototypes...
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=attiny13a -DF_CPU=1200000L -DARDUINO=10819 -DARDUINO_attiny -DARDUINO_ARCH_AVR -Wextra -flto -g -DENABLE_MICROS "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\variants\attiny13" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\sketch\Fireflies2.ino.cpp" -o "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=attiny13a -DF_CPU=1200000L -DARDUINO=10819 -DARDUINO_attiny -DARDUINO_ARCH_AVR -Wextra -flto -g -DENABLE_MICROS "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\variants\attiny13" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\sketch\Fireflies2.ino.cpp" -o "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\sketch\Fireflies2.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -x assembler-with-cpp -mmcu=attiny13a -DF_CPU=1200000L -DARDUINO=10819 -DARDUINO_attiny -DARDUINO_ARCH_AVR -DENABLE_MICROS "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\variants\attiny13" "C:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore\millis.S" -o "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\millis.S.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -x assembler-with-cpp -mmcu=attiny13a -DF_CPU=1200000L -DARDUINO=10819 -DARDUINO_attiny -DARDUINO_ARCH_AVR -DENABLE_MICROS "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\variants\attiny13" "C:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore\pcrt.S" -o "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\pcrt.S.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=attiny13a -DF_CPU=1200000L -DARDUINO=10819 -DARDUINO_attiny -DARDUINO_ARCH_AVR -Wextra -flto -g -DENABLE_MICROS "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\variants\attiny13" "C:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore\wiring_digital.c" -o "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\wiring_digital.c.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=attiny13a -DF_CPU=1200000L -DARDUINO=10819 -DARDUINO_attiny -DARDUINO_ARCH_AVR -Wextra -flto -g -DENABLE_MICROS "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\variants\attiny13" "C:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore\wiring_pulse.c" -o "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\wiring_pulse.c.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=attiny13a -DF_CPU=1200000L -DARDUINO=10819 -DARDUINO_attiny -DARDUINO_ARCH_AVR -Wextra -flto -g -DENABLE_MICROS "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\variants\attiny13" "C:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore\wiring_shift.c" -o "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\wiring_shift.c.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=attiny13a -DF_CPU=1200000L -DARDUINO=10819 -DARDUINO_attiny -DARDUINO_ARCH_AVR -Wextra -flto -g -DENABLE_MICROS "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\variants\attiny13" "C:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore\WInterrupts.c" -o "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\WInterrupts.c.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=attiny13a -DF_CPU=1200000L -DARDUINO=10819 -DARDUINO_attiny -DARDUINO_ARCH_AVR -Wextra -flto -g -DENABLE_MICROS "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\variants\attiny13" "C:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore\wiring.c" -o "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\wiring.c.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=attiny13a -DF_CPU=1200000L -DARDUINO=10819 -DARDUINO_attiny -DARDUINO_ARCH_AVR -Wextra -flto -g -DENABLE_MICROS "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\variants\attiny13" "C:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore\wiring_pwm.c" -o "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\wiring_pwm.c.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=attiny13a -DF_CPU=1200000L -DARDUINO=10819 -DARDUINO_attiny -DARDUINO_ARCH_AVR -Wextra -flto -g -DENABLE_MICROS "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\variants\attiny13" "C:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore\wiring_analog.c" -o "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\wiring_analog.c.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=attiny13a -DF_CPU=1200000L -DARDUINO=10819 -DARDUINO_attiny -DARDUINO_ARCH_AVR -Wextra -flto -g -DENABLE_MICROS "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\variants\attiny13" "C:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore\Print.cpp" -o "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\Print.cpp.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=attiny13a -DF_CPU=1200000L -DARDUINO=10819 -DARDUINO_attiny -DARDUINO_ARCH_AVR -Wextra -flto -g -DENABLE_MICROS "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\variants\attiny13" "C:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore\Tone.cpp" -o "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\Tone.cpp.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=attiny13a -DF_CPU=1200000L -DARDUINO=10819 -DARDUINO_attiny -DARDUINO_ARCH_AVR -Wextra -flto -g -DENABLE_MICROS "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\variants\attiny13" "C:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore\HalfDuplexSerial.cpp" -o "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\HalfDuplexSerial.cpp.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=attiny13a -DF_CPU=1200000L -DARDUINO=10819 -DARDUINO_attiny -DARDUINO_ARCH_AVR -Wextra -flto -g -DENABLE_MICROS "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\variants\attiny13" "C:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore\main.cpp" -o "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\main.cpp.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=attiny13a -DF_CPU=1200000L -DARDUINO=10819 -DARDUINO_attiny -DARDUINO_ARCH_AVR -Wextra -flto -g -DENABLE_MICROS "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\variants\attiny13" "C:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore\WString.cpp" -o "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\WString.cpp.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=attiny13a -DF_CPU=1200000L -DARDUINO=10819 -DARDUINO_attiny -DARDUINO_ARCH_AVR -Wextra -flto -g -DENABLE_MICROS "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\variants\attiny13" "C:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore\picoUART.cpp" -o "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\picoUART.cpp.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=attiny13a -DF_CPU=1200000L -DARDUINO=10819 -DARDUINO_attiny -DARDUINO_ARCH_AVR -Wextra -flto -g -DENABLE_MICROS "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\variants\attiny13" "C:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore\picoUART_rxISR.cpp" -o "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\picoUART_rxISR.cpp.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=attiny13a -DF_CPU=1200000L -DARDUINO=10819 -DARDUINO_attiny -DARDUINO_ARCH_AVR -Wextra -flto -g -DENABLE_MICROS "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore" "-IC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\variants\attiny13" "C:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0\cores\microcore\WMath.cpp" -o "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\WMath.cpp.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\core.a" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\millis.S.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\core.a" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\pcrt.S.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\core.a" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\WInterrupts.c.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\core.a" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\wiring.c.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\core.a" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\wiring_analog.c.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\core.a" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\wiring_digital.c.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\core.a" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\wiring_pulse.c.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\core.a" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\wiring_pwm.c.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\core.a" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\wiring_shift.c.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\core.a" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\HalfDuplexSerial.cpp.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\core.a" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\Print.cpp.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\core.a" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\Tone.cpp.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\core.a" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\WMath.cpp.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\core.a" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\WString.cpp.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\core.a" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\main.cpp.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\core.a" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\picoUART.cpp.o"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\core.a" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\core\picoUART_rxISR.cpp.o"
Archiving built core (caching) in: C:\Users\Owner\AppData\Local\Temp\arduino_cache_396358\core\core_317b65b48b377c4c7c039312ddb34c55.a
Linking everything together...
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -Wl,--gc-sections -mmcu=attiny13a -w -flto -g -o "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904/Fireflies2.ino.elf" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904\sketch\Fireflies2.ino.cpp.o" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904/core\core.a" "-LC:\Users\Owner\AppData\Local\Temp\arduino_build_346904" -lm
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904/Fireflies2.ino.elf" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904/Fireflies2.ino.eep"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904/Fireflies2.ino.elf" "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904/Fireflies2.ino.hex"
cmd /C "C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objdump" --disassemble --source --line-numbers --demangle --section=.text "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904/Fireflies2.ino.elf" > "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904/Fireflies2.ino_attiny13a_1200000L.lst"
"C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\Users\Owner\AppData\Local\Temp\arduino_build_346904/Fireflies2.ino.elf"
Sketch uses 1006 bytes (98%) of program storage space. Maximum is 1024 bytes.
Global variables use 46 bytes (71%) of dynamic memory, leaving 18 bytes for local variables. Maximum is 64 bytes.
C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18/bin/avrdude -CC:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0/avrdude.conf -v -pattiny13 -cstk500v1 -PCOM7 -b19200 -Uhfuse:w:0xfd:m -Ulfuse:w:0b00101010:m -Uflash:w:C:\Users\Owner\AppData\Local\Temp\arduino_build_346904/Fireflies2.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Owner\AppData\Local\Arduino15\packages\MicroCore\hardware\avr\2.2.0/avrdude.conf"
Using Port : COM7
Using Programmer : stk500v1
Overriding Baud Rate : 19200
An error occurred while uploading the sketch
