I'm using a new Arduino Nano and have a problem uploading via USB.
Verwende das Board 'nano' von der Plattform im Ordner: C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Verwendung des Kerns 'arduino' von Platform im Ordner: C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Verwendete Bibliotheken erkennen ...
C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs C:\Users\rolfd\AppData\Local\arduino\sketches\1AE3F5520E532A376E860EE8150E18B2\sketch\Blink.ino.cpp -o nul
Funktionsprototypen werden generiert ...
C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs C:\Users\rolfd\AppData\Local\arduino\sketches\1AE3F5520E532A376E860EE8150E18B2\sketch\Blink.ino.cpp -o C:\Users\rolfd\AppData\Local\Temp\1164074963\sketch_merged.cpp
C:\Users\rolfd\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\rolfd\AppData\Local\Temp\1164074963\sketch_merged.cpp
Sketch wird kompiliert ...
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\1AE3F5520E532A376E860EE8150E18B2\\sketch\\Blink.ino.cpp" -o "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\1AE3F5520E532A376E860EE8150E18B2\\sketch\\Blink.ino.cpp.o"
Bibliotheken werden kompiliert ...
Kern wird kompiliert ...
Verwendung des vorkompilierten Kerns: C:\Users\rolfd\AppData\Local\arduino\cores\arduino_avr_nano_cpu_atmega328_0de10db44c57759b004e66d3410cc783\core.a
Alles zusammenlinken...
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\1AE3F5520E532A376E860EE8150E18B2/Blink.ino.elf" "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\1AE3F5520E532A376E860EE8150E18B2\\sketch\\Blink.ino.cpp.o" "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\1AE3F5520E532A376E860EE8150E18B2/..\\..\\cores\\arduino_avr_nano_cpu_atmega328_0de10db44c57759b004e66d3410cc783\\core.a" "-LC:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\1AE3F5520E532A376E860EE8150E18B2" -lm
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\1AE3F5520E532A376E860EE8150E18B2/Blink.ino.elf" "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\1AE3F5520E532A376E860EE8150E18B2/Blink.ino.eep"
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\1AE3F5520E532A376E860EE8150E18B2/Blink.ino.elf" "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\1AE3F5520E532A376E860EE8150E18B2/Blink.ino.hex"
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\1AE3F5520E532A376E860EE8150E18B2/Blink.ino.elf"
Der Sketch verwendet 924 Bytes (3%) des Programmspeicherplatzes. Das Maximum sind 30720 Bytes.
Globale Variablen verwenden 9 Bytes (0%) des dynamischen Speichers, 2039 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes.
"C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -patmega328p -carduino "-PCOM13" -b115200 -D "-Uflash:w:C:\Users\rolfd\AppData\Local\arduino\sketches\1AE3F5520E532A376E860EE8150E18B2/Blink.ino.hex:i"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM13
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x50
Upload via AVRisp MK2 no problems. When I upload via USB I have problems (see last post).
FQBN: arduino:avr:nano
C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs C:\Users\rolfd\AppData\Local\arduino\sketches\F11B0C436BF9770772ADF0478C181D10\sketch\Blinki_ATtiny.ino.cpp -o nul
C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs C:\Users\rolfd\AppData\Local\arduino\sketches\F11B0C436BF9770772ADF0478C181D10\sketch\Blinki_ATtiny.ino.cpp -o C:\Users\rolfd\AppData\Local\Temp\3253105174\sketch_merged.cpp
C:\Users\rolfd\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\rolfd\AppData\Local\Temp\3253105174\sketch_merged.cpp
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10\\sketch\\Blinki_ATtiny.ino.cpp" -o "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10\\sketch\\Blinki_ATtiny.ino.cpp.o"
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.elf" "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10\\sketch\\Blinki_ATtiny.ino.cpp.o" "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10/..\\..\\cores\\arduino_avr_nano_cpu_atmega328_0de10db44c57759b004e66d3410cc783\\core.a" "-LC:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10" -lm
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.elf" "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.eep"
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.elf" "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.hex"
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.elf"
Der Sketch verwendet 932 Bytes (3%) des Programmspeicherplatzes. Das Maximum sind 30720 Bytes.
"C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -patmega328p -cstk500v2 -Pusb "-Uflash:w:C:\Users\rolfd\AppData\Local\arduino\sketches\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.hex:i"
Using Port : usb
Using Programmer : stk500v2
avrdude: usbdev_open(): Found AVRISP mkII, serno: 000200074968
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel STK500 Version 2.x firmware
Programmer Model: AVRISP mkII
Hardware Version: 1
Firmware Version Master : 1.24
Vtarget : 5.0 V
SCK period : 8.00 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "C:\Users\rolfd\AppData\Local\arduino\sketches\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.hex"
avrdude: writing flash (932 bytes):
Writing | ################################################## | 100% 0.29s
avrdude: 932 bytes of flash written
avrdude: verifying flash memory against C:\Users\rolfd\AppData\Local\arduino\sketches\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.hex:
avrdude: load data flash data from input file C:\Users\rolfd\AppData\Local\arduino\sketches\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.hex:
avrdude: input file C:\Users\rolfd\AppData\Local\arduino\sketches\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.hex contains 932 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.30s
avrdude: verifying ...
avrdude: 932 bytes of flash verified
avrdude done. Thank you.
I have done a bootloader update via AVRisp MK2 from ARDUINO IDE. But USB upload does not work
Bootloader update protocol:
"C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -patmega328p -cstk500v2 -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
Using Port : usb
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 1
Vtarget : 5.1 V
avrdude: reading input file "C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -patmega328p -cstk500v2 -Pusb "-Uflash:w:C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6/bootloaders/optiboot/optiboot_atmega328.hex:i" -Ulock:w:0x0F:m
"0x3F"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3F:
avrdude: load data lock data from input file 0x3F:
avrdude: input file 0x3F contains 1 bytes
avrdude: reading on-chip lock data:
avrdude: 1 bytes of lock verified
avrdude: reading input file "0xFD"
avrdude: writing efuse (1 bytes):
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xFD:
avrdude: load data efuse data from input file 0xFD:
avrdude: input file 0xFD contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0xDA"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xDA:
avrdude: load data hfuse data from input file 0xDA:
avrdude: input file 0xDA contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xFF"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xFF:
avrdude: load data lfuse data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
Using Port : usb
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 1
Vtarget : 5.1 V
avrdude: reading input file "C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6/bootloaders/optiboot/optiboot_atmega328.hex"
avrdude: writing flash (32768 bytes):
avrdude: 32768 bytes of flash written
avrdude: verifying flash memory against C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6/bootloaders/optiboot/optiboot_atmega328.hex:
avrdude: load data flash data from input file C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6/bootloaders/optiboot/optiboot_atmega328.hex:
avrdude: input file C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6/bootloaders/optiboot/optiboot_atmega328.hex contains 32768 bytes
avrdude: 32768 bytes of flash verified
avrdude: reading input file "0x0F"
Writing | ################################################## | 100% 0.01s
avrdude: verifying lock memory against 0x0F:
avrdude: load data lock data from input file 0x0F:
avrdude: input file 0x0F contains 1 bytes
Hi @rolfdegen .
When you do that, it erases the bootloader. The "stk500_recv(): programmer is not responding" error message you encountered while trying to upload via USB is what we expect to see when you attempt to upload to a board that doesn't have a bootloader (though there are also several other potential causes of this generic error message).
So if you perform this sequence:
Perform "Burn Bootloader" operation.
Perform "Upload Using Programmer" operation.
Attempt upload via USB.
Then it is expected that the upload will fail at step (3).
But if you instead perform this sequence:
Then we would expect the upload at step (2) to be successful.
So please try burning the bootloader again to make sure it is present on the board, then try uploading via USB once more. Hopefully it will be successful this time.
pert
January 12, 2025, 1:10pm
5
Since it was not relevant to the original discussion, I have split your posts out to their own topic @rolfdegen . Please use this topic for all further discussion of the upload problem you are experiencing.
Thanks in advance for your cooperation.
pert
January 12, 2025, 1:14pm
6
@rolfdegen I see you are still posting in the irrelevant topic, even after I asked you not to do that. Please pay attention!
If you won't respond to polite requests, I will be forced to give you an account suspension to get your attention. I don't want to do that, and I'm sure you don't want that either.
Excuse me but my English is not very good.
Thanks for the tip. I'll try it.
Unfortunately it didn't work. I flashed the bootloader via AVRISP MK2. Then loaded the sketch via USB. Error message:
C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs C:\Users\rolfd\AppData\Local\arduino\sketches\F11B0C436BF9770772ADF0478C181D10\sketch\Blinki_ATtiny.ino.cpp -o C:\Users\rolfd\AppData\Local\Temp\1009344417\sketch_merged.cpp
C:\Users\rolfd\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\rolfd\AppData\Local\Temp\1009344417\sketch_merged.cpp
"C:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\rolfd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -patmega328p -carduino "-PCOM13" -b115200 -D "-Uflash:w:C:\Users\rolfd\AppData\Local\arduino\sketches\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.hex:i"
Using Port : COM13
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xb0
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xb0
User abort
My system info:
Windows 11 Home 24H2 build 26100.2605
CPU Intel(R) Core(TM) i5-8600K CPU @ 3.60GHz 3.60 GHz
RAM 16GB
New Arduino Nano from AZ-Delivery Nano V3.0 CH340
How to change the upload speed in Arduino IDE?
I have change Boudrate form COM13 to 115200 in my Windows Setup.. But ohne Erfolg !! Warum funktioniert das nicht grrrrrrrrrrrrrr
Ok. I saw that the baud rate for COM13 is overwritten from upload. Can you please reduce the baud rate for uplade in Arduino IDE !? I will try it.
This indicates that you have selected the 328P under tools/processor.
You either bought a very old original Nano or a clone. Try the 328P (old bootloader) option; if that fails, try the 168 option. And if that fails please provide sharp photos of the top and bottom of the boar so we can read the print on the ICs.
Below for a clone with CH340
Thanks for the tip. I updated the bootloader with AVRisp MK2 (see 3.post). I tried 328 (old bootloader) and also 168. No success. I have win driver CH340 change. No success.
My Pic from new Ardoino Nano
Is your board flashing the normal blink sequence (1 second on, one second off)?
If you press and release the reset button, do you get a single quick flash before the above blink sequence starts or does it give a few quick flashes before the above blink sequence starts?
No. Only LED "Pow" is constantly lit. The other LEDs are off
I have now ordered an original Arduino Nano V3 from Reichelt. This costs twice as much and I hope that it works
In that case it sounds like there is no bootloader. If there is no "normal" blink pattern the 328P was either not programmed at the factory or is faulty.
Thank you very much for your help. I will return the Arduino Nano and try an original one. I wanted to use an Arduino Nano as a programmer for an ATtinsy412. That was my idea
Hello. I programmed the Arduino Nano via USB. First I programmed the Nano via AVRISP MK2 (COM3) with the sketch for UPDI programmer "jtag2updi-master". Then I removed the AVRISP MK2. I connected the Nano to the ATtiny412 as shown in the circuit diagram and connected the Nano to a USB2.0 port on my PC (not a USB hub). Then I changed the setting for programmer to "jtag2updi" and set COM13 and set 10MHz clock for ATtiny. Next I loaded a sketch (Blink) and transferred it to the ATtiny via "Upload using Programmer". It worked without any errors. LED Rx and LED Tx from Nono lights during upload.
Link: GitHub - ElTangas/jtag2updi: UPDI programmer software for Arduino (targets Tiny AVR-0/1/2, Mega AVR-0 and AVR-DA/DB MCUs)
Link: GitHub - SpenceKonde/ATTinyCore: Arduino core for ATtiny 1634, 828, x313, x4, x41, x5, x61, x7 and x8
Link: https://wolles-elektronikkiste.de/megatinycore-nutzen
FQBN: megaTinyCore:megaavr:atxy2:clock=10internal
Verwende das Board 'atxy2' von der Plattform im Ordner: C:\Users\rolfd\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.6.10
Verwendung des Kerns 'megatinycore' von Platform im Ordner: C:\Users\rolfd\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.6.10
C:\Users\rolfd\AppData\Local\Arduino15\packages\DxCore\tools\avr-gcc\7.3.0-atmel3.6.1-azduino7b1/bin/avr-g++ -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=attiny412 -DF_CPU=10000000L -DCLOCK_SOURCE=0 -DTWI_MORS -DMILLIS_USE_TIMERD0 -DCORE_ATTACH_ALL -DTCA_PORTMUX=0x01 -DARDUINO=10607 -DARDUINO_AVR_ATtiny412 -DARDUINO_ARCH_MEGAAVR -DMEGATINYCORE="2.6.10" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=6UL -DMEGATINYCORE_PATCH=10UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy2 -IC:\Users\rolfd\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.6.10\cores\megatinycore/api/deprecated -IC:\Users\rolfd\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.6.10\cores\megatinycore -IC:\Users\rolfd\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.6.10\variants\txy2 C:\Users\rolfd\AppData\Local\arduino\sketches\F11B0C436BF9770772ADF0478C181D10\sketch\Blinki_ATtiny.ino.cpp -o nul
C:\Users\rolfd\AppData\Local\Arduino15\packages\DxCore\tools\avr-gcc\7.3.0-atmel3.6.1-azduino7b1/bin/avr-g++ -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=attiny412 -DF_CPU=10000000L -DCLOCK_SOURCE=0 -DTWI_MORS -DMILLIS_USE_TIMERD0 -DCORE_ATTACH_ALL -DTCA_PORTMUX=0x01 -DARDUINO=10607 -DARDUINO_AVR_ATtiny412 -DARDUINO_ARCH_MEGAAVR -DMEGATINYCORE="2.6.10" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=6UL -DMEGATINYCORE_PATCH=10UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy2 -IC:\Users\rolfd\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.6.10\cores\megatinycore/api/deprecated -IC:\Users\rolfd\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.6.10\cores\megatinycore -IC:\Users\rolfd\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.6.10\variants\txy2 C:\Users\rolfd\AppData\Local\arduino\sketches\F11B0C436BF9770772ADF0478C181D10\sketch\Blinki_ATtiny.ino.cpp -o C:\Users\rolfd\AppData\Local\Temp\2136017600\sketch_merged.cpp
C:\Users\rolfd\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\rolfd\AppData\Local\Temp\2136017600\sketch_merged.cpp
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\DxCore\\tools\\avr-gcc\\7.3.0-atmel3.6.1-azduino7b1/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=attiny412 -DF_CPU=10000000L -DCLOCK_SOURCE=0 -DTWI_MORS -DMILLIS_USE_TIMERD0 -DCORE_ATTACH_ALL -DTCA_PORTMUX=0x01 -DARDUINO=10607 -DARDUINO_AVR_ATtiny412 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.6.10\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=6UL -DMEGATINYCORE_PATCH=10UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy2 "-IC:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\megaTinyCore\\hardware\\megaavr\\2.6.10\\cores\\megatinycore/api/deprecated" "-IC:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\megaTinyCore\\hardware\\megaavr\\2.6.10\\cores\\megatinycore" "-IC:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\megaTinyCore\\hardware\\megaavr\\2.6.10\\variants\\txy2" "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10\\sketch\\Blinki_ATtiny.ino.cpp" -o "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10\\sketch\\Blinki_ATtiny.ino.cpp.o"
Verwendung des vorkompilierten Kerns: C:\Users\rolfd\AppData\Local\arduino\cores\2a88c5ac1583edb9e7fb91cfed682b12\core.a
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\DxCore\\tools\\avr-gcc\\7.3.0-atmel3.6.1-azduino7b1/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -Wl,--section-start=.text=0x0 -mmcu=attiny412 -o "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.elf" "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10\\sketch\\Blinki_ATtiny.ino.cpp.o" "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10/..\\..\\cores\\2a88c5ac1583edb9e7fb91cfed682b12\\core.a" "-LC:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10" -lm
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\DxCore\\tools\\avr-gcc\\7.3.0-atmel3.6.1-azduino7b1/bin/avr-objcopy" -O binary -R .eeprom "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.elf" "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.bin"
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\DxCore\\tools\\avr-gcc\\7.3.0-atmel3.6.1-azduino7b1/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.elf" "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.eep"
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\DxCore\\tools\\avr-gcc\\7.3.0-atmel3.6.1-azduino7b1/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.elf" "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.hex"
cmd /C echo. && "C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\DxCore\\tools\\avr-gcc\\7.3.0-atmel3.6.1-azduino7b1/bin/avr-objdump" --disassemble --source --line-numbers --demangle --section=.text "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.elf" > "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.lst"
cmd /C echo. && "C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\DxCore\\tools\\avr-gcc\\7.3.0-atmel3.6.1-azduino7b1/bin/avr-nm" --numeric-sort --line-numbers --demangle --print-size --format=s "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.elf" > "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.map"
"C:\\Users\\rolfd\\AppData\\Local\\Arduino15\\packages\\DxCore\\tools\\avr-gcc\\7.3.0-atmel3.6.1-azduino7b1/bin/avr-size" -A "C:\\Users\\rolfd\\AppData\\Local\\arduino\\sketches\\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.elf"
Der Sketch verwendet 448 Bytes (10%) des Programmspeicherplatzes. Das Maximum sind 4096 Bytes.
Globale Variablen verwenden 10 Bytes (3%) des dynamischen Speichers, 246 Bytes für lokale Variablen verbleiben. Das Maximum sind 256 Bytes.
"C:\Users\rolfd\AppData\Local\Arduino15\packages\DxCore\tools\avrdude\6.3.0-arduino17or18/bin/avrdude" "-CC:\Users\rolfd\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.6.10/avrdude.conf" -v -V -pattiny412 -cjtag2updi -PCOM13 -b115200 "-Ufuse0:w:0b00000000:m" "-Ufuse2:w:0x02:m" "-Ufuse5:w:0b11000101:m" "-Ufuse6:w:0x04:m" "-Ufuse7:w:0x00:m" "-Ufuse8:w:0x00:m" "-Uflash:w:C:\Users\rolfd\AppData\Local\arduino\sketches\F11B0C436BF9770772ADF0478C181D10/Blinki_ATtiny.ino.hex:i"
avrdude: Version 6.3-20201216
System wide configuration file is "C:\Users\rolfd\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.6.10/avrdude.conf"
Using Port : COM13
Using Programmer : jtag2updi
JTAG ICE mkII sign-on message:
Communications protocol version: 1
M_MCU:
boot-loader FW version: 1
firmware version: 6.00
hardware version: 1
S_MCU:
hardware version: 1
Serial number: 00:00:00:00:00:00
Device ID: JTAGICE mkII
AVR Part : ATtiny412
Chip Erase delay : 0 us
PAGEL : P00
BS2 : P00
RETRY pulse : SCK
Timeout : 0
StabDelay : 0
CmdexeDelay : 0
SyncLoops : 0
ByteDelay : 0
PollIndex : 0
PollValue : 0x00
Memory Detail :
prodsig 0 0 0 0 no 61 61 0 0 0 0x00 0x00
fuses 0 0 0 0 no 9 10 0 0 0 0x00 0x00
fuse0 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse1 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse2 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse4 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse5 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse6 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse7 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse8 0 0 0 0 no 1 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 0 0 0x00 0x00
data 0 0 0 0 no 0 0 0 0 0 0x00 0x00
usersig 0 0 0 0 no 32 32 0 0 0 0x00 0x00
flash 0 0 0 0 no 4096 64 0 0 0 0x00 0x00
eeprom 0 0 0 0 no 128 32 0 0 0 0x00 0x00
Programmer Type : JTAGMKII_PDI
Description : JTAGv2 to UPDI bridge
M_MCU hardware version: 1
M_MCU firmware version: 6.00
S_MCU hardware version: 1
S_MCU firmware version: 6.00
Vtarget : 5.0 V
avrdude: jtagmkII_initialize(): Cannot locate "flash" and "boot" memories in description
Reading | ################################################## | 100% 0.04s
avrdude: Device signature = 0x1e9223 (probably t412)
avrdude: reading input file "0b00000000"
avrdude: writing fuse0 (1 bytes):
avrdude: 1 bytes of fuse0 written
avrdude: reading input file "0x02"
avrdude: writing fuse2 (1 bytes):
avrdude: 1 bytes of fuse2 written
avrdude: reading input file "0b11000101"
avrdude: writing fuse5 (1 bytes):
avrdude: 1 bytes of fuse5 written
avrdude: reading input file "0x04"
avrdude: writing fuse6 (1 bytes):
Writing | avrdude: jtagmkII_recv(): checksum error
################################################## | 100% 0.26s
avrdude: 1 bytes of fuse6 written
avrdude: reading input file "0x00"
avrdude: writing fuse7 (1 bytes):
avrdude: 1 bytes of fuse7 written
avrdude: writing fuse8 (1 bytes):
avrdude: 1 bytes of fuse8 written
avrdude: writing flash (448 bytes):
Writing | ###################################avrdude: jtagmkII_recv(): checksum error
avrdude: jtagmkII_paged_write(): timeout/error communicating with programmer (status -4)
############### | 100% 0.65s
avrdude: 448 bytes of flash written
