Hello
searched and tested anything I found on the internet about my problem:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
went through the troubleshooting#upload too!
Bit it still persists
OS:Windows 7 64bit
board: arduino pro mini 5v (16Mhz) 328 (selected in the arduino software)
cable: FTDI
when I plug the arduino in the device manager appears COM4 so I select this also in the arduino software (I guess this means I'm not having driver problems, right? cause I did in the begining)
Intersting is that when I plug the arduino in the PC I see a green and a red led blick once. In the troubleshooting it says the green should be on all the time.
removed windows firewall and all the programs in the back - teamviewer, deamon tools, skype etc.
in the USB settings in the device manager I changed the Port Settings to 115200 Bits per second they were 9600 as default. 115200 bps is know to be an arduino environment. Is this true?
I've attached a pic how I've connected the arduino to the cable. Hope I have connected it correctly, haven't I?
Thanks you
