Hi Every one.
Below is the output from the ide.
Arduino: 1.8.19 (Linux), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
/home/db/Documents/arduino-1.8.19/arduino-builder -dump-prefs -logger=machine -hardware /home/db/Documents/arduino-1.8.19/hardware -tools /home/db/Documents/arduino-1.8.19/tools-builder -tools /home/db/Documents/arduino-1.8.19/hardware/tools/avr -built-in-libraries /home/db/Documents/arduino-1.8.19/libraries -libraries /home/db/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=1A86_7523 -ide-version=10819 -build-path /tmp/arduino_build_337471 -warnings=none -build-cache /tmp/arduino_cache_221700 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/home/db/Documents/arduino-1.8.19/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/home/db/Documents/arduino-1.8.19/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/home/db/Documents/arduino-1.8.19/hardware/tools/avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/home/db/Documents/arduino-1.8.19/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/home/db/Documents/arduino-1.8.19/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/home/db/Documents/arduino-1.8.19/hardware/tools/avr -verbose /home/db/Documents/arduino-1.8.19/examples/01.Basics/Blink/Blink.ino
/home/db/Documents/arduino-1.8.19/arduino-builder -compile -logger=machine -hardware /home/db/Documents/arduino-1.8.19/hardware -tools /home/db/Documents/arduino-1.8.19/tools-builder -tools /home/db/Documents/arduino-1.8.19/hardware/tools/avr -built-in-libraries /home/db/Documents/arduino-1.8.19/libraries -libraries /home/db/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=1A86_7523 -ide-version=10819 -build-path /tmp/arduino_build_337471 -warnings=none -build-cache /tmp/arduino_cache_221700 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/home/db/Documents/arduino-1.8.19/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/home/db/Documents/arduino-1.8.19/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/home/db/Documents/arduino-1.8.19/hardware/tools/avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/home/db/Documents/arduino-1.8.19/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/home/db/Documents/arduino-1.8.19/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/home/db/Documents/arduino-1.8.19/hardware/tools/avr -verbose /home/db/Documents/arduino-1.8.19/examples/01.Basics/Blink/Blink.ino
Using board 'nano' from platform in folder: /home/db/Documents/arduino-1.8.19/hardware/arduino/avr
Using core 'arduino' from platform in folder: /home/db/Documents/arduino-1.8.19/hardware/arduino/avr
Detecting libraries used...
/home/db/Documents/arduino-1.8.19/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/db/Documents/arduino-1.8.19/hardware/arduino/avr/cores/arduino -I/home/db/Documents/arduino-1.8.19/hardware/arduino/avr/variants/eightanaloginputs /tmp/arduino_build_337471/sketch/Blink.ino.cpp -o /dev/null
Generating function prototypes...
/home/db/Documents/arduino-1.8.19/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/db/Documents/arduino-1.8.19/hardware/arduino/avr/cores/arduino -I/home/db/Documents/arduino-1.8.19/hardware/arduino/avr/variants/eightanaloginputs /tmp/arduino_build_337471/sketch/Blink.ino.cpp -o /tmp/arduino_build_337471/preproc/ctags_target_for_gcc_minus_e.cpp
/home/db/Documents/arduino-1.8.19/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_337471/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/home/db/Documents/arduino-1.8.19/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/db/Documents/arduino-1.8.19/hardware/arduino/avr/cores/arduino -I/home/db/Documents/arduino-1.8.19/hardware/arduino/avr/variants/eightanaloginputs /tmp/arduino_build_337471/sketch/Blink.ino.cpp -o /tmp/arduino_build_337471/sketch/Blink.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /tmp/arduino_cache_221700/core/core_arduino_avr_nano_cpu_atmega328old_93719608d7a032a1552fc3166d971f79.a
Linking everything together...
/home/db/Documents/arduino-1.8.19/hardware/tools/avr/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /tmp/arduino_build_337471/Blink.ino.elf /tmp/arduino_build_337471/sketch/Blink.ino.cpp.o /tmp/arduino_build_337471/../arduino_cache_221700/core/core_arduino_avr_nano_cpu_atmega328old_93719608d7a032a1552fc3166d971f79.a -L/tmp/arduino_build_337471 -lm
/home/db/Documents/arduino-1.8.19/hardware/tools/avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /tmp/arduino_build_337471/Blink.ino.elf /tmp/arduino_build_337471/Blink.ino.eep
/home/db/Documents/arduino-1.8.19/hardware/tools/avr/bin/avr-objcopy -O ihex -R .eeprom /tmp/arduino_build_337471/Blink.ino.elf /tmp/arduino_build_337471/Blink.ino.hex
/home/db/Documents/arduino-1.8.19/hardware/tools/avr/bin/avr-size -A /tmp/arduino_build_337471/Blink.ino.elf
Sketch uses 924 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/home/db/Documents/arduino-1.8.19/hardware/tools/avr/bin/avrdude -C/home/db/Documents/arduino-1.8.19/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b57600 -D -Uflash:w:/tmp/arduino_build_337471/Blink.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/home/db/Documents/arduino-1.8.19/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/home/db/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: ser_open(): can't open device "/dev/ttyUSB0": Permission denied
avrdude done. Thank you.
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
