I need your help :(. I'm trying to get angle values from PST-360 angle sensor using my Banana Pi BPI-Leaf-S3 (ESP32 S3 development board). I've found a thread (Getting 0 values from a rotary position sensor - SOLVED!) where guys managed to connect to Arduino UNO R3.
I've took the source code that was tagged as working and made small corrections (because I'm not using MOSFET in my case).
Unfortunately, I don't get any response from my PST-360 device. Currently, I'm stuck in a corner. Maybe someone could give me advice on how to move forward.
Wiring diagram:
#include <Arduino.h>
#include <SPI.h>
const uint8_t CS_PIN = 10;
while (!Serial.available());
Serial.println(MOSI); // Black 11
Serial.println(MISO); // Black R10 13
Serial.println(SCK); // Grey 12
Serial.println(SS); //CS White 10
pinMode(CS_PIN, OUTPUT);
digitalWrite(CS_PIN, HIGH);
SPI.begin();
delay(20);
/*A data frame consists of 10 bytes:
• 2 start bytes (AAh followed by FFh)
• 2 data bytes (DATA16 – most significant byte first)
• 2 inverted data bytes (/DATA16 – most significant byte first)
• 4 all-Hi bytes
uint8_t data[10] = {0};
int index = 0;
//min time between each bit transfer is 7 microseconds so set to 125kHz which is the lowest
SPI.beginTransaction(SPISettings(125000, MSBFIRST, SPI_MODE1));
//Start transaction
digitalWrite(CS_PIN, LOW);
delayMicroseconds(20);
//Send start byte
data[index++] = SPI.transfer(0xAA);
delayMicroseconds(50);
//Send and receive data bytes
for(uint8_t i = 1; i < 10; i++){
data[index++] = SPI.transfer(0xFF);
delayMicroseconds(40);
//End transaction
SPI.endTransaction();
//Extract and calculate angle
uint16_t data_bytes = (data[2] << 8) | data[3]; // Combine two bytes
uint16_t first14 = data_bytes >> 2; // Extract first 14 bits
float value = (float)(first14 / 16384.0); // Divide by 2^14 and multiply by 360 to get degrees
float angle = (value - 0.1)/(0.9 - 0.1) * 360;
//Serial.println(angle);
for (int i = 0; i < 10; i++)
Serial.print(data[i], HEX);
delay(100);
Results from Logic Analyser:
Command description from documentation(https://www.piher.net/wp-content/uploads/Piher_-Serial_Protocol_V01.pdf):
I'm just a hobby maker not a professional, what I'm missing there? Thank you in advance.
