Can't control WS2812B LED strip with FastLED
I used to be able to make it work with this setup, which consists of an Arduino UNO and a WS2812 LED strip, but it no longer works. This is the connection diagram:
And this is how I set it up:
The sketch I'm using:
#include <FastLED.h>
#define NUM_LEDS 1
#define DATA_PIN 3
// Define the array of leds
CRGB leds[NUM_LEDS];
    FastLED.addLeds<WS2812B, DATA_PIN, RGB>(leds, NUM_LEDS);  // GRB ordering is typical
  // Turn the LED on, then pause
  leds[0] = CRGB::Red;
  FastLED.show();
  // Now turn the LED off, then pause
  leds[0] = CRGB::Black;
  digitalWrite(13, LOW);
  FastLED.show();
Is there anything wrong with my setup that made the strip unusable or something or is the board just dead?
In your diagram the LED Data In pin is connected to the 5V pin of the Uno via a capacitor and the 5V pin of the LEDs is connected to pin 7 of the Uno
Why ?
Sorry about that. The strip I'm using has the Din pin in the middle and I just assumed it's the same in thinkercard
Please post a schematic of how your project is actually wired
I updated the diagram, and the capacitor is used to level out the power to the LED strip. I tried connecting without it and 7 first LED just turned on even when there is no data pin connected
This is the wiring diagram I used.
The capacitor must be between +5V and GND (red and black) on this way the strip hasn't power.
That is a rude thing to do because it makes comments about the original diagram nonsense
Why is the capacitor in series with the 5v line ? No current will flow through it. Shouldn't the capacitor be connected across GND and 5V lines instead ?
I'm sorry, I will edit it back the original way
So is it like this?
Better, but the capacitor is the wrong way round
Help! After wiring up the schematic and powering the Arduino, some of the LEDs turned on unexpectedly, and I still can't control the LED after uploading the sketch.
In the schematic you use D7 as DATA out. In your program you use
Why you use a strip with x Leds and you use
Use a number as much you use leds. Make all the leds "Black" at startup.
I've changed the code accordingly, but it still does not work.
I wonder why some of the first LEDs just start lighting up and I can't do anything about it
#define NUM_LEDS 600
#define DATA_PIN 7
  FastLED.show();
  FastLED.show();
Try this from the Fastled examples
// This function runs over and over, and is where you do the magic to light
// your leds.
   // Move a single white led
   for(int whiteLed = 0; whiteLed < NUM_LEDS; whiteLed = whiteLed + 1) {
      // Turn our current led on to white, then show the leds
      leds[whiteLed] = CRGB::White;
      // Show the leds (only one of which is set to white, from above)
      FastLED.show();
      // Wait a little bit
      delay(100);
      // Turn our current led back to black for the next loop around
      leds[whiteLed] = CRGB::Black;
edit:
In setup you can place
  fill_solid(leds, NUM_LEDS, CRGB(0, 0, 0));
  FastLED.show();
to make all leds black.
I have worked up with the code:
#define DATA_PIN 7
    FastLED.show();
      FastLED.show();
      delay(100);
This is my actual wiring. The data pin is 7, and I used the above schematic with a flipped capacitor. Is anything wrong with my setup
I've tried i it again and again, still no luck
Why that resistor between data and GND?
Try another datapin maybe you have molded the pin.
