I am using an Arduino Micro board connected to an Adafruit BNO055 IMU sensor. I cannot detect the board and when I run an I2C scanner it detects nothing. Here are the connections and photos Arduino Pin 2 to SDA Arduino Pin 3 to SCL Arduino 5v to Vin Arduino GND to GND
This was one of my first times soldering and did not do a great job, did I fry the board or anything? Would love to hear anyone's thoughts on this. Thanks!
I have my sensor wired up the same as yours was however if I run the I2C Wire Scanner it will not detect the sensor. I think it is also important to note I have had this sensor working for a while and had this problem in the past. I can not recall how I was able to solve it though.
Sorry for the late reply, I always thought that the BNO055 already had pull-up resistors built-in, I've been able to get it to work a lot before without these resistors as well.
Another sensible course of action is to get out your multimeter and check for correct voltages, broken wires, intermittent connections or shorts between pins.
Okay, I was wrong and it does need those resistors. I was using it for a good couple of weeks before this happened and it worked fine. Would running this without those resistors cause the board to be permanently damaged?
I also checked for shorts and wire connections which all were as expected.
The Arduino core enables the internal pullup resistors, which are weak, but sometimes adequate to allow I2C to function. Then if you change the wiring, it stops working.
Having the same Project right now but using an esp8266 with the Arduino IDE. In my case it works perfectly fine without resistor. I had do define this Adafruit_BNO055 IMU = Adafruit_BNO055(-1, 0x28) to make it work.
There will be some resistance, depending on the polarity of the probes and the internal circuitry of the multimeter. I would expect that to be a few thousand Ohms.
In my code, I was defining it with
Adafruit_BNO055 IMU = Adafruit_BNO055(55), Still not able to detect the board but I will try this change once I can get the board connected.
