Same here, I can't select the port. It says "Select Other Board & Port" but I can only select a different board. Help.
Ducky-Entertainment
"Mee Too" has very little detail.
Could you take a few moments to Learn How To Use The Forum.
It will help you get the best out of the forum as a whole.
Bob.
I had the same issue on my MAC: I saw my board connected but I could not upload any code. After some unsucessful search in the forums, I decided to investigate myself; Here is what I found and what worked for me:
first I checked if the port was available:
(base) MacBook-Pro-de-Andreas:~ andreas$ ls /dev/usb
/dev/cu.usbserial-1410 /dev/tty.usbserial-1410
Note: you see the port only if the board is plugged in (no reboot needed as suggested in some other answers)
then, select the correct port in the arduino web editor:
click the drop-down for selecting the board: DONT use the option "Select other Board&Port"
but just select the option above listing the available port
in my case "Arduino Uno at /dev/cu.usbserial-1410"
after that selection, my upload worked fine ![]()
