This tells you what all your pins are.
http://www.ebay.com/itm/3-2-TFT-320-x-240-LCD-Display-Module-with-Touch-Panel-PCB-Adapter-/271233625422
follow it.
follow it.
These are the pins on your screen, all you need to do is match them up.
25 |
TP_SO |
Touch screen SPI data output |
connects to SPI MISO, Pin 30 |
26 |
TP_IRQ |
Touch screen interrupt |
Low level while the touch screen detects pressing Pin 28 on Shield |
27 |
TP_SI |
Touch screen data input |
connects to SPI MOSI, Pin 34 on Shield |
29 |
TP_SCK |
Touch screen SPI clock |
connects to SPI SCK, Pin 32 |
31 |
TP_CS |
Touch screen chip select |
Low active, Pin 20 |
there is no place to connect them in the 32 pin
i tried to connect out to miso
in to mosi
clk to clk
and still nothing
yes i connected
mosi to mosi
miso to miso
clk to clk
and it didn't work
and after that i connected
mosi to TP_SI
miso to TP_SO
clk to TP_CLK and CLK
but nothing xD
I don't know what else to tell you other than to get a adapter shield made for your screen, instead of trying to wire it yourself.
thats what i'm going to do
hope my screen isn't damaged in the first place
Just for the case somebody read it in attempt to solve a problem with touchscreen:
check your 5V level.
Some USB ports have not enough power, and touch sensor seems too sensitive to low voltage.
