Hi there!
Just wanted to try something, downloaded the latest IDE and got my old Duemilanove out of the closet. Uploaded a sketch, which includes some Serial communication with 115200 baud, without problems.
Then I changed something in the script and wanted to upload again. I got
avrdude: ser_open(): can't open device "\\.\COM3": Access denied
interestingly, when I switch over to the Serial Monitor, I receive messages without problem. I can even send messages to the Arduino. However, I can't seem to upload a sketch again. I tried rebooting a couple times, reinstalled the IDE. I also tried to reset the Arduino before the upload starts, without luck.
It seems like the Serial Monitor is using the Serial Port and doesn't release it to upload a sketch? Or am I misinterpreting this?
Thanks!
Update: Managed to kill the Serial Monitor through the Task Manager. Upload worked again!
So I guess this is a bug report?
kolaha
May 16, 2023, 10:52pm
3
it is normal. only one device can work at a time. stop it and other device will be able to connect.
sometimes IDE greyout serial monitor while upload, sometimes not and it must be closed manually.
Hi @GoingForGold . The Arduino IDE developers are tracking this bug here:
opened 07:07AM - 23 Dec 22 UTC
topic: code
type: imperfection
### Describe the problem
In order to upload to an Arduino board via a serial β¦ port, the upload tool (e.g., [**AVRDUDE**](https://github.com/avrdudes/avrdude)) must be able to open the port. This is not possible if another process already has control of the port.
Arduino IDE's "Serial Monitor" and and "Serial Plotter" components also use the serial port of the board. Arduino IDE handles this potential conflict of port usage automagically by closing the port in Serial Monitor/Plotter when an upload process is triggered, then opening it again after the upload is finished. This means no special action is needed from the user to upload while Serial Monitor/Plotter is open.
π The upload fails with an "`Access is denied`" error under the following conditions:
- The board uses an FTDI FT232R USB chip
- Arduino IDE is running on a Windows machine
- Serial Monitor or Serial Plotter is open
I've been using Arduino IDE 2.0.3 with Nano without issues when uploading on Ubuntu. Now I've tried it on Windows 11, and most of the time, it gives me this error:
```text
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\macie\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM5
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can't open device "\\.\COM5": Access is denied.
But I can see logs from the serial monitor in Arduino IDE -> serial monitor.
### To reproduce
#### Equipment
A board or other device that has an [FTDI FT232R USB chip](https://ftdichip.com/products/ft232rl/)
The [classic **Arduino Nano**](https://docs.arduino.cc/hardware/nano) is a common board that uses this chip.
FT232R modules ([example](https://docs.arduino.cc/retired/other/usb-serial-converter)) or cables ([example](https://www.sparkfun.com/products/9717)) are also often used to upload to boards such as the [**Arduino Pro Mini**](https://www.sparkfun.com/products/11113) that don't have an integrated USB chip.
The fault can be reproduced even if the FT232R-based device is not an Arduino board. In this case, the upload is expected to fail, but it would fail with a "`not in sync`" error instead of "`Access is denied`".
#### Steps
1. Select **File > New Sketch** from the Arduino IDE menus.
1. Connect the Arduino board to your computer.
1. Select the board and port from the Arduino IDE menus.
1. If the Serial Monitor view is not already open, select **Tools > Serial Monitor** from the Arduino IDE menus to open it.
1. Select **Sketch > Upload** from the Arduino IDE menus.
1. Wait for the upload process to finish.
π The upload fails:
```text
Using Port : COM5
1. Click the **X** icon on the "**Serial Monitor**" view tab in the bottom panel.
π The upload is successful.
1. Select **Tools > Serial Plotter** from the Arduino IDE menus.
π The upload fails:
```text
Using Port : COM5
1. Close the "**Serial Plotter**" window.
π The upload fails:
```text
Using Port : COM5
**β** This unexpected result is caused by a separate bug: https://github.com/arduino/arduino-ide/issues/1423
### Expected behavior
Serial Monitor and Serial Plotter do not interfere with upload process.
### Arduino IDE version
#### Original report
2.0.3
#### Last verified with
692f29f
### Operating system
Windows
### Operating system version
Edition Windows 11 Pro
Version 22H2
Installed on 07/11/2022
OS build 22621.963
Experience Windows Feature Experience Pack 1000.22638.1000.0
### Additional context
I bisected the introduction of the fault to df8658e
I have no problems uploading sketches on Arduino IDE 1.8.19 from Microsoft Store on the same system. I can quit 2.0.3, start 1.8.19, and it's working immediately.
I cannot reproduce the fault on Linux (Ubuntu 22.04) or macOS (Ventura).
I cannot reproduce the fault when using native USB boards (e.g., [**Leonardo**](https://docs.arduino.cc/hardware/leonardo), [**MKR**](https://docs.arduino.cc/#mkr-family)) or boards that use other models of dedicated USB chip (e.g., ATmega16U2 on Uno and Mega, WCH CH340 on derivative boards).
<a name="workaround"></a>
#### Workaround
<a name="serial-monitor"></a>
##### Serial Monitor
1. Click the **X** icon on the "**Serial Monitor**" tab in the bottom panel of the Arduino IDE window to close the tab:
1. Upload the sketch.
1. Open **Serial Monitor** again if needed (by clicking the icon on the IDE toolbar or the **Tools > Serial Monitor** menu item) after the upload is finished.
<a name="serial-plotter"></a>
##### Serial Plotter
1. If the "**Serial Monitor**" view is not already open, select **Tools > Serial Monitor** from the Arduino IDE menus to open it.
**β** We must do an open/close cycle on **Serial Monitor** as a workaround for [a bug](https://github.com/arduino/arduino-ide/issues/1423) in **Serial Plotter**
1. Open **Serial Monitor** and/or **Serial Plotter** again if needed after the upload is finished.
#### Additional reports
- https://forum.arduino.cc/t/arduino-nano-not-able-to-upload-comx-port-access-denied/1081669/15
- https://forum.arduino.cc/t/elusive-uno-upload-error-access-is-denied/1067785/5
- https://forum.arduino.cc/t/port-issues-with-ide-2-0-3/1069090
- https://forum.arduino.cc/t/fdti-breakout-2-types-cause-usb-acess-denial/1088005
- https://forum.arduino.cc/t/port-access-is-denied/1089761
- https://forum.arduino.cc/t/cant-open-device-when-uploading-but-serial-monitor-works/1127731
- https://github.com/arduino/arduino-ide/issues/1937
- https://github.com/arduino/arduino-ide/issues/726#issuecomment-1464313325
### Issue checklist
- [X] I searched for previous reports in [the issue tracker](https://github.com/arduino/arduino-ide/issues?q=)
- [X] I verified the problem still occurs when using the latest [nightly build](https://www.arduino.cc/en/software#nightly-builds)
- [X] My report contains all necessary details
If you have a GitHub account, you can subscribe to that issue to get notifications of any new developments related to this subject.
