Can't read data from Bluetooth module
Hello there..
I'm trying out my first Bluetooth controller with my arduino uno. So I bought the HC-05 and started testing it with android bluetooth RC apps.
I hooked up the VCC and GND, and TxD and RxD to pins I set using Software serial library.
Here is my code:
#include<SoftwareSerial.h>
#define RxD 10
#define TxD 11
SoftwareSerial BT(RxD,TxD);
  pinMode(RxD,INPUT);
  pinMode(TxD,OUTPUT);
  pinMode(13,OUTPUT);
  setupBT();
    int x;
    if(BT.available()>0)
     {x=BT.read();
    Serial.println(x);}
    if(x==1) digitalWrite(13,HIGH);
    else digitalWrite(13,LOW);
void setupBT()
  BT.begin(9600);
  BT.print("\r\n+STWMOD=0\r\n");
  BT.print("\r\n+STNA=HC-05\r\n");
  BT.print("\r\n+STOAUT=1\r\n");
  BT.print("\r\n+STAUTO=0\r\n");
  BT.flush();
Is my code correct? Or is it a problem with my module or uno? Because the serial monitor is not showing the sent data neither is the led glowing.. i have tried two android apps but it doesnt respond to commands from both.
Thank you for your time and advice.
  pinMode(RxD,INPUT);
You told the software serial instance that it could use these pins. Quit diddling with them.
    int x;
x now contains random garbage.
So, unless you read a 1 from the bluetooth device, turn the LED off. Since it is a near certainty that the Android send a '1', not a 1, you will always turn the LED off.
Do you  BT.begin(9600);
  BT.flush();
Send some data. Wait a while. Then, block until all the data has been sent. Why? What purpose does that delay() serve?
Are you CERTAIN that the bluetooth device paired with your phone?
