I'm trying to have a bidirectional communication between MKR1000 and Python from my host computer.
Code from MKR1000:
#include <WiFi101.h>
#include <SPI.h>
// To connect to the server on laptop
char ssid[] = "id";
char pass[] = "pass";
int status = WL_IDLE_STATUS;
IPAddress server(172,20,10,3);
WiFiClient client;
// Random variable
int a, i, j, k;
byte buf0[7];
byte buf1[7];
Serial1.begin(115200);
pinMode(LED_BUILTIN, OUTPUT);
status = WiFi.begin(ssid, pass);
if (status != WL_CONNECTED) {
while (status != WL_CONNECTED) {
j = client.connect(server, 1234);
while (j != 1) {
if (client.available()) {
a = client.read();
if (a == 0) { // Send new target to Due
j = 0;
while(j<6) {
if (client.available()>0) {
buf0[j] = client.read();
j++;
Serial1.write((byte) 0);
// Send coordinate back to Due
for (i = 0; i<6; i++) {
Serial1.write(buf0[i]);
} else if (a == 1) {
// Get the coordinate from the Due
Serial1.write((byte) 1);
k = 0;
while(k < 6) {
if (Serial1.available() > 0) {
buf1[k] = Serial1.read();
k++;
for (i=0;i<6;i++) {
client.write(buf1[i]);
client.write((byte) 0); // fill in the blank size
} else if (a == 2) { // identify yourself
Serial.println("Identify myself.");
client.write((byte) 1);
Code from Python:
import socket
import time
def coor2bytes(coor_fnc):
coorByte = [0, 0, 0, 0, 0, 0]
if (coor_fnc[0] >= 0):
coorByte[0] = (coor_fnc[0] >> 8) & 0xFF # High byte of X
coorByte[1] = coor_fnc[0] & 0xFF # Low byte of X
else:
coor_fnc[0] = coor_fnc[0]*(-1)
coorByte[0] = coorByte[0] ^ 0x80
if (coor_fnc[1] >= 0):
coorByte[2] = (coor_fnc[1] >> 8) & 0xFF # High byte of Y
coorByte[3] = coor_fnc[1] & 0xFF # Low byte of Y
else:
coor_fnc[1] = coor_fnc[1]*(-1)
coorByte[2] = (coor_fnc[1] >> 8) & 0xFF # High byte of X
coorByte[2] = coorByte[2] ^ 0x80
coorByte[3] = coor_fnc[1] & 0xFF # Low byte of X
if (coor_fnc[2] >= 0):
coorByte[4] = (coor_fnc[2] >> 8) & 0xFF # High byte of Phi
coorByte[5] = coor_fnc[2] & 0xFF # Low byte of Phi
else:
coor_fnc[2] = coor_fnc[2]*(-1)
coorByte[4] = coorByte[4] ^ 0x80
return coorByte
def bytes2coor(byte_fnc):
receivedCoor_fnc = [0, 0, 0]
receivedCoor_fnc[0] = ((-1)**(byte_fnc[0]>>7)) * ((byte_fnc[1]) | (((byte_fnc[0]&0x7f)<<8)))
receivedCoor_fnc[1] = ((-1)**(byte_fnc[2]>>7)) * ((byte_fnc[3]) | (((byte_fnc[2]&0x7f)<<8)))
receivedCoor_fnc[2] = ((-1)**(byte_fnc[4]>>7)) * ((byte_fnc[5]) | (((byte_fnc[4]&0x7f)<<8)))
return receivedCoor_fnc
if __name__ == '__main__':
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.bind((socket.gethostname(), 1234)) # bind(ip, port)
print("Done binding.")
s.listen(2)
clientsocket, address = s.accept()
print(f"Connection from {address} has been established!")
# time.sleep(5)
print("Ask for ID.")
# Identify the client
client_id = -1
while(client_id == -1):
clientsocket.send(bytes([2]))
print("I asked.")
client_id = clientsocket.recv(8)
client_id = int.from_bytes(client_id, 'little')
if client_id == 1:
print("This is Alpha.")
else:
print("I have no idea who this is.")
print("The id is: " + str(client_id))
while True:
print();
print("What you want to do?")
print("0. Send target")
print("1. Get current coordinate")
print("2. Set current coordinate (not yet implement)")
try:
a = int(input("I choose: "))
except Exception:
print("Error.")
a = -1;
if (a == 0):
coor = [0, 0, 0]
try:
coor[0] = int(input("X: "))
coor[1] = -int(input("y: "))
coor[2] = int(input("phi: "))
coorByte = coor2bytes(coor)
except Exception:
print("Error.")
clientsocket.send(bytes([0]))
clientsocket.send(bytes(coorByte))
print("I already sent the target.")
elif (a == 1):
clientsocket.send(bytes([1]))
bytesReceived = []
full_msg = []
while (len(full_msg) < 8):
bytesReceived = clientsocket.recv(8)
for x in range(len(bytesReceived)):
full_msg.append(bytesReceived[x])
receivedCoor = bytes2coor(full_msg)
print("coordinate received: " + str(receivedCoor))
else:
print("Not yet implement.")
I know it's a lot of code but really you can just have a look at the MKR code and this particular section on the Python:
s.listen(2)
# time.sleep(5)
client_id = -1
print("I asked.")
For some reason, I can't seem to get the MKR response back, UNLESS I turn on the MKR first, wait for 1 or 2 seconds, and then run the Python script.
Any insight?
