Can't upload a sketch to arduino uno
I bought 3 arduino boards from diffrent Aliexpress sellers. I have problems with uploading sketch to all three of them. The arduino ide keeps stucking on uploading. I tried using another arduino as the isp programer but arduino ide says:
Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
Do you have any ideas how to solve it?
Your boards might not have the standard 328P processor. So you need to check which processor is actually on the boards.
Please enable verbose output during upload and disable verbose output during compilation and perform an upload of e.g. the blink example. Please post the output here using code tags (easiest is probably to use the <CODE/> button).
Repeat the exercise with the arduino as isp and post the results here as well.
One of them has mega328p for sure. The other two propably have lgt8f328p.
Here are the details of uploading using USB port:
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM4
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xca
avrdude done.  Thank you.
Problem uploading to board.  See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
Ten raport powinien zawierać więcej informacji jeśli w
File -> Preferencje zostanie włączona opcja "Pokaż
szczegółowe informacje podczas kompilacji"
And here using another adruino as a programer for the board with lgt8f328p:
         Using Port                    : COM7
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
Podczas ładowania szkicu wystąpił błąd
Reading | ################################################## | 100% 0.03s
avrdude: Yikes!  Invalid device signature.
         this check.
On othe board with mega328p weird things happened, it seems that the blink sketch uploaded, but the led is not blinking:
         Using Port                    : COM7
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "C:\Users\nomys\AppData\Local\Temp\arduino_build_353359/Blink.ino.hex"
avrdude: writing flash (924 bytes):
Writing | ################################################## | 100% 1.11s
avrdude: 924 bytes of flash written
avrdude: verifying flash memory against C:\Users\nomys\AppData\Local\Temp\arduino_build_353359/Blink.ino.hex:
avrdude: load data flash data from input file C:\Users\nomys\AppData\Local\Temp\arduino_build_353359/Blink.ino.hex:
avrdude: input file C:\Users\nomys\AppData\Local\Temp\arduino_build_353359/Blink.ino.hex contains 924 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.62s
avrdude: verifying ...
avrdude: 924 bytes of flash verified
If you press and release the reset button, do you get a single quick flash or 3 flashes in quick succession?
Boards should come pre-loaded with the blink sketch; is that indeed running? If not, the board might also not have a bootloader.
To my knowledge this means that the programmer can't communicate properly with the bootloader.
For those, I suggest that you install GitHub - dbuezas/lgt8fx: Board Package for Logic Green LGT8F328P LGT8F328D and LGT8F88D.
Does the Tools menu have a processor option, I have some NANOs with 3 choices and it's the old version that works.
