Can't upload sketch to my Arduino Nano
Hi all,
I need some help to fix this issue, I can not longer upload sketches to my Arduino Nano. Here is the upload log:
Sketch uses 930 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.wchusbserial141420 -b115200 -D -Uflash:w:/var/folders/d7/nqlhz82s4jj0b582yjwc3qfh0000gn/T/arduino_build_62822/Blink.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/laurent/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.wchusbserial141420
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "/var/folders/d7/nqlhz82s4jj0b582yjwc3qfh0000gn/T/arduino_build_62822/Blink.ino.hex"
avrdude: writing flash (930 bytes):
Writing | ################################################## | 100% 0.49s
avrdude: 930 bytes of flash written
avrdude: verifying flash memory against /var/folders/d7/nqlhz82s4jj0b582yjwc3qfh0000gn/T/arduino_build_62822/Blink.ino.hex:
avrdude: load data flash data from input file /var/folders/d7/nqlhz82s4jj0b582yjwc3qfh0000gn/T/arduino_build_62822/Blink.ino.hex:
avrdude: input file /var/folders/d7/nqlhz82s4jj0b582yjwc3qfh0000gn/T/arduino_build_62822/Blink.ino.hex contains 930 bytes
avrdude: reading on-chip flash data:
Reading | #####################################An error occurred while uploading the sketch
############# | 100% 0.45s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
0xff != 0x0c
avrdude: verification error; content mismatch
avrdude done. Thank you.
Thank you for your help.
picture of nano board
Look for "Arduino AVR Boards", select the last version (1.6.23)
Does your LED goes on and off when pressing reset button ??
