Can't upload
I'm new to Arduino and I was just testing my board with a simple alteration to the Blink code (just changing the output pin to blink a led on a breadboard) and i'm geting this error message when I try to upload:
Arduino: 1.8.8 (Windows 7), Board: "Arduino/Genuino Uno"
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
Using Port: COM3
Using Programmer: arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x20
An error occurred while uploading the sketch
avrdude done. Thank you.
I'm sure it's not the code, but here is what i'm trying to upload:
  pinMode (7, OUTPUT);
  digitalWrite(7, HIGH);
  digitalWrite(7, LOW);
Thanks
Remove any connections to pins 0 and 1. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don’t know which port is your Arduino, you can find it like this:
  • Unplug your Arduino board from the computer.
  • Tools > Port
  • Note the ports, if any, listed in the menu.
  • Close the Tools menu
  • Plug your Arduino board into the computer.
  • Tools > Port - The new port listed in the menu is your Arduino board.
If the Tools > Port menu is grayed or the port of your Arduino does not appear on the menu:
  • Make sure your USB cable is fully inserted into the Arduino board and the computer.
  • You may need to install the driver for the USB-serial chip on your Arduino.
  • You may be using a charge-only or defective USB cable. Try a different cable or test your cable on another device to confirm that it works for data.
  • Using a USB 3.0 port on your computer may cause problems. Try a USB 2.0 port.
First of all, thank you for your answer.
I've opened the device manager and I saw that my board wasn't recognized.
I've updated the driver and it works.
Thanks again. :slight_smile:
I'm glad to hear it's working now. Thanks for taking the time to provide an update. Enjoy!
Per
