I already installed a 12v rgb setup in my car, I wanted to use one of my steering wheel buttons to control the footwell lights to switch on and off. Does anyone know of any module that does this. It needs to have R G B +12v for the input then an on//off switch in middle that I can hook up to the steering wheel button (tactile button) and R G B +12v for the output for this to work. This will be located in between the main unit and the footwell lights. Can anyone help me out, iv already got all the wiring sorted for this to work. If this is not an option then I could possibly do it via the power input, so the input 12v+ 12v- to on//off tactile switch to 12v+ 12v- if anyone can direct me to something that would work I’d be very greatfull.
Why do you think that you need to switch all R G B and power lines? Is it not enough to turn on the power?
The best way, however, will be to control the module, that produces the RGB signal.
you can use mono stable 12V relay, it will cut +12V for rgb.
There’s already an on and off switch for the main unit that powers all the RGB lights in the car, I want to separate the footwell RGBs which is connected directly to the main unit so they turn on and off independently. For me to do this I need this on and off switch to work through all the wires otherwise it wouldn’t work. I have also got sub units that connect wirelessly to the main unit automatically and if I wire this unit to the footwell lights then I’d just need the switch to control this on and off through the 12v+ & 12v- input. But I can’t seem to find anything as I don’t know what I’m looking for.
This would be perfect didn’t think you can cut power to just one connection, is it possible to send a link to where I can purchase somthing like this please?
