I am trying to chain together 5 LEDs in series, and 10 sets of these 5 chains in parallel. I am running into a voltage issue, as each LED has a power draw of 2.2V. I have looked into a couple of different solutions, and am looking for opinions on what would be optimal. If it helps, I am making a turn signal system for a bike. I am looking specifically in using the VIN pin with a 12V power supply and transistors. Any input is welcome.
You can't do that directly from an Arduino output.
You need a transistor to sink current from a 12V source. An Arduino output controls the transistor.
I would recommend AOD514 from Digikey if you are comfortable with surface mount parts.
It is vital you get your vocabulary correct when talking technical matters.
Each LED drops 2.2V across it, this is not a power draw.
So as you have found out 5 times 2.2V = 11V.
In order to have enough voltage to make a resistor work as a current limiter you need one or two voltage drops spare so to speak, so you are looking at a voltage of about 15V.
You have two choices, supply that voltage or rearrange the LEDs to match what you do have.
