You are testing the TIP122 out of circuit?
Please post a picture of you doing the Collector negative and Emitter positive test, with the DMM in Diode Test mode.
Where are you purchasing your TIP122?
I agree, sounds like its a counterfeit or its zapped.
Tom...
2112
October 13, 2023, 11:16pm
22
The TO220 type leads are hard on the breadboard contacts. Maybe you should verify continuity?
ginetom
October 13, 2023, 11:34pm
23
I'm brazilian. I'm buying from an online store(Mercado Livre) where there is a seller of car accessories(GRUPO2B)
I also think it's a fake product...
I had already tested this continuity of conductors issue and they are conducting normally
ginetom
October 13, 2023, 11:57pm
24
I took some measurements and found this
PROBE
PROBE
POSITIVE
NEGATIVE
RESULT
Base
Colector
-10.75V
Colector
Base
10.75V
Base
Emitter
0V
Emissor
Base
0V
Colector
Emitter
10.73V
Emitter
Colector
-10.73V
JCA34F
October 14, 2023, 2:24am
25
Is the TIP122's emitter connected to the 3.3V source's ground?
If the 3.3V source is a GPIO pin, is it able to source 11.87mA?
Did you connect the GPIO pin to the TIP122 base without a resistor in series?
ginetom
October 14, 2023, 4:34am
26
I'm using 3.3V from ESP32(GPIO).
Yes. According to the datasheet, it is capable of up to 20mA.
In this test, I mean that I connected the 220 ohm resistor directly to the GPIO to make sure that the GPIO would be able to provide 15 mA. Through the multimeter, I came to the conclusion that it did.
When you have the circuit connected to power an the controller, and you make the GPIO go high, please measure the GPIO to gnd voltage, then the base to gnd voltage.
Then emitter pin of the transistor to the controller gnd pin.
In both cases negative probe to gnd.
Thanks.. Tom..
ginetom
October 14, 2023, 4:54am
28
TomGeorge:
GPIO -> GND = 3.29V;
Base -> GND = 3.29V;
Emitter -> GND = 3.29V;
Colector -> GND = 14V
JCA34F
October 14, 2023, 5:04am
30
Sounds like you have the load in the emitter circuit.
cherk
October 14, 2023, 5:08am
31
More than likely the emitter is NOT grounded !!
JCA34F
October 14, 2023, 5:17am
33
Well, shows the worth of pictures and generic "schematics" found on "the web".
ginetom
October 14, 2023, 5:45am
34
In all the images I sent here, the negative of the power supply and the ESP32 GND are interconnected.
LarryD:
Done
I took opportunity to switch to another ESP
I took the measurements again and this was the result.
GPIO -> GND = 3.31V;
Base -> GND = 3.31V;
Emitter -> GND = 3.31V;
Colector -> GND = 12.5V
LarryD
October 14, 2023, 5:49am
35
If the emitter is connected to GND and if the voltmeter negative lead is on GND, you must be measuring this incorrectly.
ginetom
October 14, 2023, 6:08am
38
Problem solved... Ridiculously high resistance of this jumpe
ginetom
October 14, 2023, 6:12am
40
LarryD:
Bad contact as well... Simple thing I hadn't thought of. Strange that I had previously tested continuity and no problem.
Thank you so much.
