Transistor and its behavior
Hi, i have a problem with my circuit, it works, but i don't know why.
I want to power an LED strip using arduino, tip122 transistor, 1k ohm resistor and 12 volts from 8 AA batteries.
Problem is that when i connect arduino ground to the ground on breadboard (to "-" side of batteries), Led strip does get a little bit brighter, when P2 is HIGH, but never turns off, only gets dimmer a bit, when p2 is LOW
when i connect arduino ground to the drain/emitter of the tip122 it works (turns off completely, when p2 is LOW), but i don't know why, and i think that this isn't the way it should work.
I have attached two fabulous fritzing drawings, hope it will help you help me. :slight_smile:
And sorry if im being stupid, i am new to the arduino and don't know the flamability of this comunity.
(please, don't be like xda or stackoverflow people, please :smiley: )
And another apologies for any english mistakes i've made.
Arduino Ground must be connected to battery -.
Pinout of TIP-122 is Base, Collector, Emitter, in that order.
You've got the collector and emitter switched - you want the negative side of the load going to the collector, and the emitter connected to ground.
123 BCE
Why do you have the collector connected to the negative terminal of the battery? It isn't acting as a transistor, that is why it isn't responding the way it should.
Please consider learning to draw schematics, they are much clearer. And you'll often catch errors.
Thank you, i accidentally made my batterypack reverse so the red wire is "-" fuck, at least i know why it was doing all those funky things. Thank you for your kindness. I tried to draw schematics too, but i was like, what if i messed up with breadboard or something :slight_smile: sorry again.
