hi, so I am a beginner in Arduino programming and I don't have much experience in programming recently I made a obstacle avoiding car and a Bluetooth controlled car and now I want to make a car where I can have those two features and I can change modes from obstacle avoiding and Bluetooth controlling just by pressing a button from my phone I have trying to do it for a few days but I was unsuccessful somebody please tell me how I can add this feature
Welcome to the forum
Please post your best attempt at combining the 2 sketches, using code tags when you do, and describe the problems that you have had
I don't normally complain about grammar, but you really need to use punctuation to allow your text to be read normally...
And once you have actual sentences, it's customary to capitalize the first word of each one.
#include <AFMotor.h>
#include <SoftwareSerial.h>
#include <NewPing.h>
#include <Servo.h>
#define TRIG_PIN A0
#define ECHO_PIN A1
#define MAX_DISTANCE 200
#define MAX_SPEED 190 // sets speed of DC motors
#define MAX_SPEED_OFFSET 20
SoftwareSerial bluetoothSerial(0, 1); // RX, TX
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE);
//initial motors pin
AF_DCMotor motor1(1, MOTOR12_1KHZ);
AF_DCMotor motor2(2, MOTOR12_1KHZ);
AF_DCMotor motor3(3, MOTOR34_1KHZ);
AF_DCMotor motor4(4, MOTOR34_1KHZ);
Servo myservo;
char command;
boolean goesForward=false;
int distance = 100;
int speedSet = 0;
int test = 33;
bluetoothSerial.begin(9600);
myservo.attach(10);
myservo.write(115);
delay(2000);
distance = readPing();
delay(100);
delay(100);
delay(100);
delay(100);
int distanceR = 0;
int distanceL = 0;
if (bluetoothSerial.available() > 0) {
command = bluetoothSerial.read();
Stop();
switch (command) {
case 'F':
forward();
case 'B':
back();
case 'L':
left();
case 'R':
right();
case 'V':
test = 33;
case 'v':
test = 34;
if(test=34){
if(distance<=30)
moveStop();
delay(400);
moveBackward();
delay(300);
else{}
}else{
if(distance<=30)
moveStop();
delay(100);
moveBackward();
delay(300);
moveStop();
delay(200);
distanceR = lookRight();
delay(200);
distanceL = lookLeft();
delay(200);
if(distanceR>=distanceL)
turnRight();
moveStop();
}else
turnLeft();
moveStop();
}else
moveForward();
int lookRight()
myservo.write(50);
int distance = readPing();
delay(100);
myservo.write(115);
return distance;
int lookLeft()
myservo.write(170);
delay(100);
myservo.write(115);
return distance;
delay(100);
int readPing() {
delay(0);
int cm = sonar.ping_cm();
if(cm==0)
cm = 100;
return cm;
void moveStop() {
motor1.run(RELEASE);
motor2.run(RELEASE);
motor3.run(RELEASE);
motor4.run(RELEASE);
void moveBackward() {
goesForward=false;
motor1.run(BACKWARD);
motor2.run(BACKWARD);
motor3.run(BACKWARD);
motor4.run(BACKWARD);
for (speedSet = 0; speedSet < MAX_SPEED; speedSet +=2)
motor1.setSpeed(speedSet);
motor2.setSpeed(speedSet);
motor3.setSpeed(speedSet);
motor4.setSpeed(speedSet);
delay(5);
void forward()
motor1.setSpeed(255); //Define maximum velocity
motor1.run(FORWARD); //rotate the motor clockwise
motor2.setSpeed(255); //Define maximum velocity
motor2.run(FORWARD); //rotate the motor clockwise
motor3.setSpeed(255); //Define maximum velocity
motor3.run(FORWARD); //rotate the motor clockwise
motor4.setSpeed(255); //Define maximum velocity
motor4.run(FORWARD); //rotate the motor clockwise
void back()
motor1.run(BACKWARD); //rotate the motor anti-clockwise
motor2.run(BACKWARD); //rotate the motor anti-clockwise
motor3.run(BACKWARD); //rotate the motor anti-clockwise
motor4.run(BACKWARD); //rotate the motor anti-clockwise
void left()
void right()
void Stop()
motor1.setSpeed(0); //Define minimum velocity
motor1.run(RELEASE); //stop the motor when release the button
motor2.setSpeed(0); //Define minimum velocity
motor2.run(RELEASE); //rotate the motor clockwise
motor3.setSpeed(0); //Define minimum velocity
motor3.run(RELEASE); //stop the motor when release the button
motor4.setSpeed(0); //Define minimum velocity
motor4.run(RELEASE); //stop the motor when release the button
void moveForward() {
if(!goesForward)
goesForward=true;
delay(5);
void turnRight() {
void turnLeft() {
This is my recent attempt on this project
So I am using an android app called Bluetooth RC Controller. and I have used the horn button to change the modes when I uploaded the code to my Arduino UNO the Bluetooth controlling works fine but when I turn it on the obstacle avoiding mode it doesn't work
Sorry for that
Sorry for that.
This is always true because you use the "=" operator to assign 34 to test, then the expression evaluates to non-zero and triggers the if(...) clause, and then you do a about a second's worth of object avoidance before you loop again and get a chance to read another bluetooth character.
Really? A software serial instance on the existing, functional hardware serial pins? Why not just use the existing hardware serial port?
Why? What does this accomplish?
That's a non-blocking delay().
a7
Thanks
your code needs at least 2 sub-functions: one that monitors for commands and a second that runs the robot, presumably autonomously in obstacle avoidance mode.
the obstacle avoidance sub-function is repeatedly invoke depending on a mode flag that can be toggled using a command. when NOT in obstacle avoidance mode, user controlled commands (i.e. "teleop")
are allowed. the mode flag can be used to check for or ignore those commands by calling a 3rd sub-function
it's about organizing the code
but it looks like your obstacle avoidance code, autonomously executes various move commands, is blocking and would need to complete before seeing another command
