How About This:-
---- Transmitter Code ----
Mert Arduino Tutorial & Projects (YouTube)
Please Subscribe for Support
#include <SPI.h> //the communication interface with the modem
#include "RF24.h" //the library which helps us to control the radio modem
int msg[1];
RF24 radio(8,10); //5 and 10 are a digital pin numbers to which signals CE and CSN are connected.
const uint64_t pipe = 0xE8E8F0F0E1LL; //the address of the modem, that will receive data from Arduino.
void setup(void){
radio.begin(); //it activates the modem.
radio.openWritingPipe(pipe); //sets the address of the receiver to which the program will send data.
void loop(void){
msg[0] = map (analogRead(0), 0, 1023, 0, 179);
radio.write(msg, 1);
---- Receiver Code ----
#include <Servo.h> //the library which helps us to control the servo motor
Servo myServo; //define the servo name
RF24 radio(8,10); /This object represents a modem connected to the Arduino.
Arguments 5 and 10 are a digital pin numbers to which signals
CE and CSN are connected./
const uint64_t pipe = 0xE8E8F0F0E1LL; //the address of the modem,that will receive data from the Arduino.
int msg[1];
void setup(){
myServo.attach(3); //3 is a digital pin to which servo signal connected.
radio.openReadingPipe(1, pipe); //determines the address of our modem which receive data.
radio.startListening(); //enable receiving data via modem
void loop(){
if(radio.available()){ //checks whether any data have arrived at the address of the modem
bool done = false; //returns a “true” value if we received some data, or “false” if no data.
while (!done) {
done = radio.read(msg, 1);
myServo.write(msg[0]);
