STRLEN() doesnt return a expected number
I know this function cant go wrong so I must be doing something wrong.
bool newData = true;
char *AXpos;
char *EYpos;
const char *delimiter = ",";
//char inData[numChars];  // an array to store the received data
char inData = "123.45,678.90\n";  // an array to store the received data
  Serial.begin(9600);  // initialize serial communication
  while (!Serial) {
    delay(0);
  int length = strlen(inData);
  Serial.println(length);//should be 14 but returns 9
  extractData();
  exit(0);
void extractData() {
  //Extract two numbers from received data
  if (newData == true) {
    AXpos = strtok(inData, delimiter);
    EYpos = strtok(NULL, delimiter);
    Serial.print(AXpos);
    int length = strlen(AXpos);
    Serial.println(length); // should be 6 but returns 3
So what do I mis??
char inData[] = "123.45,678.90\n";  // an array to store the received data
char inData[], not char inData.
Dollars to donuts if you turned your warning level up to all, the compiler would have told you that.
Edit: yes, with warning=all, the compiler complained at length.
char is a datatype that can contains only a single letter (char).
To save a string you need an array of chars, so
Overflow.
This equals 9.
char inData[] = "12345678\n";  // an array to store the received data
This equals 1.
char inData[] = "12345678xn";  // an array to store the received data
It removes the escape character and overflows.
Try...
char inData[] = {"123.45,678.90\n"};
int length = sizeof(inData)/sizeof(inData[0]);
OK thanx, for the first section it works:
char *AXpos;
char *EYpos;
  while (!Serial) {
    delay(0);
  extractData();
  delay(1);
  while(true);
    Serial.println(AXpos);
 //   int length = sizeof(AXpos);
 //   Serial.println(strlen(AXpos));  // should be 6 but returns 3
   int length1 = sizeof(AXpos);
 Serial.println(length1);
 Serial.println(EYpos);
   int length2 = sizeof(EYpos);
 Serial.println(length2);
But how should I declace AXpos and EYpos becourse boht lengths is 2
The size of a pointer is 2 bytes for an R3.
If you want the length of the string it points to, you use strlen of course.
I can see from your code that you know how to spell strlen(). So why did write STRLEN() in the title or this thread?
Problem solved,
char *AXpos;
char *EYpos;
  while (!Serial) {
    delay(0);
  extractData();
  delay(1);
  while (true)
  int length;
    // prepare data for further processing
    AXpos[length] = '\0';// make a zero terminated string
    length = strlen(EYpos) - 1;// this string contains a '\n' so length-1
    EYpos[length] = '\0';
    //    Serial.println(strlen(EYpos));
now on to the next part thnx
You might want to revisit this
strtok() will add a null char where the delimiter is found and that's a good thing otherwise strlen(AXpos) would not works since strlen() relies on the presence of the null char to determine the length ➜ so AXpos[length] = '\0';// make a zero terminated string is useless.
for EYpos, if you were to look for \n as a separator too, then you would not have to get rid of the trailing line feed ➜ use const char *delimiter = ",\n";
➜ try this
  const char * AXpos = strtok(inData, delimiter);
  const char * EYpos = strtok(NULL, delimiter);
  Serial.print("AXpos = ["); Serial.print(AXpos); Serial.println("]");
  Serial.print("EYpos = ["); Serial.print(EYpos); Serial.println("]");
void loop() {}
if I typed that right, you should see (console at 115200 bauds)
AXpos = [123.45]
EYpos = [678.90]
note that your pointers do point inside the inData buffer, so don't rely on these pointers once you start listening for new incoming data - either make a copy or extract the value into a float or double (you can use strtod() for that)
the exit(0) is messing up the output. Basically kills it before you see anything. As far as I can tell.
-jim lee
