I am working on some code where I need to make an unsigned int into a string with a given number of digits in it for display on an LCD display. The following is the function I am using for this:
char * uintToString(unsigned int value, int numChars){
char digitsChar[] = {'0', '1', '2', '3', '4', '5', '6', '7', '8', '9'};
char retVal[numChars + 1];
int index = numChars - 1;
// Initialize for given number of characters
for (int i = 0; i < numChars; i++){
retVal[i] = '0';
retVal[numChars] = '\0';
// Convert the unsigned in to a string
while (value >= 10){
retVal[index--] = digitsChar[value % 10];
value = value / 10;
retVal[index] = digitsChar[value];
return retVal;
So, if I pass value = 1065 and numChars = 4, on return I get 0065. If I put in a Serial.print as shown here (or a delay, or almost any other statement) and change nothing else, I get 1065 as expected.
// Convert the unsigned int to a string
value = value / 10;
Serial.print(retVal); // Can also replace with delay(10)
return retVal;
Could someone please help me with figuring out why I get this behavior? I am totally stumped here.
sprintf() is very powerful and will work, but it's an H-bomb-to-kill-an-ant and uses more memory than you need because of unused features of the function. You might use something like:
Serial.print("Enter an unsigned int: ");
char input[6];
int charsRead;
int numChars = 5; // We'll assume you want a field of 5 digits
if (Serial.available() > 0) {
charsRead = Serial.readBytesUntil('\n', input, sizeof(input) - 1);
input[charsRead] = '\0'; // Make it a string...
uintToString(input, numChars); //Now pad the input
Serial.print("Input = ");
Serial.println(input);
* Purpose: to pad number with leading 0's for desired field width
* Parameter list:
* char *s input digit characters
* int fieldWidth the desired width of field
* Return value:
* void
* CAUTION: assumes s is big enough to hold digit chars, pad, and null
void uintToString(char *s, int fieldWidth)
char temp[6];
int len = strlen(s);
int i;
if (len == fieldWidth) { // Already desired width
return;
len = fieldWidth - len; // How many '0'
temp[0] = '\0'; // Since we use strcat()
for (i = 0; i < len; i++) {
strcat(temp, "0"); // Add leading '0'
strcat(temp, s); // add original string on...
strcpy(s, temp); // copy all back to original string
