string length help
hello I've added some code to my project to convert an intigar to a string then a char, however when its converted to a string only the first digit of the int gets displayed (e.g. int = 3.14 and the string value = 3)
below is the section of code that does the conversion.
    int a=v2;     //declaring integer
  char b[2];   //declaring character array
  String str;  //declaring string
 char input[30];
  str=String(a); //converting integer into a string
 str.toCharArray(input, 30);
the v2 is the int that is being converted into char input
thanks in advance for your help,
JOSH
Hi Josh
int = 3.14
Integers are whole numbers. They do not have a fractional part.
Check out the "data types" section here: http://arduino.cc/en/Reference/HomePage
Regards
Ray
To convert a numeric variable to a character array, you don't need to use Strings (capital S). You can go directly to a character array aka (small s) string using sprintf.
What do you want to do with the character array once it has the numeric value converted into it?
hi thanks for your quick responce !
heres all of my code
#include "ST7565.h"
 const int numReadings = 10;
int readings[numReadings];      // the readings from the analog input
int index = 0;                  // the index of the current reading
int total = 0;                  // the running total
int average = 0;                // the average
int inputPin = A0;
 float vPow = 4.9;
 float r1 = 18000;
 float r2 = 4700;
 int psu = 3;
 // the LCD backlight is connected up to a pin so you can turn it on & off
#define BACKLIGHT_LED 10
// pin 9 - Serial data out (SID)
// pin 8 - Serial clock out (SCLK)
// pin 7 - Data/Command select (RS or A0)
// pin 6 - LCD reset (RST)
// pin 5 - LCD chip select (CS)
ST7565 glcd(9, 8, 7, 6, 5);
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH  16
    // turn on backlight
  pinMode(BACKLIGHT_LED, OUTPUT);
  digitalWrite(BACKLIGHT_LED, HIGH);
  // initialize and set the contrast to 0x18
  glcd.begin(0x18);
glcd.clear();
   for (int thisReading = 0; thisReading < numReadings; thisReading++)
    readings[thisReading] = 0;
   // Send ANSI terminal codes
   Serial.print("\x1B");
   Serial.print("[2J");
   Serial.println("[H");
   // End ANSI terminal codes
   Serial.println("--------------------");
   Serial.println("DC VOLTMETER");
   Serial.print("Maximum Voltage: ");
   Serial.print((int)(vPow / (r2 / (r1 + r2))));
   Serial.println("V");
   Serial.println("");
   delay(2000);
     // subtract the last reading:
  total= total - readings[index];
  // read from the sensor:
  readings[index] = analogRead(inputPin);
  // add the reading to the total:
  total= total + readings[index];
  // advance to the next position in the array:
  index = index + 1;
  // if we're at the end of the array...
  if (index >= numReadings)
    // ...wrap around to the beginning:
    index = 0;
  // calculate the average:
  average = total / numReadings;
   analogWrite(psu, 56);
   float v = (average * vPow) / 1024.0;
   float v2 = v / (r2 / (r1 + r2));
 char input[30];
 str.toCharArray(input, 30);  //passing the value of the string to the character array
glcd.clear();
  glcd.drawstring(0, 5, input);
   glcd.display();
   Serial.println(b);
the idea simpily is that it reads A0 smooths the reading, by creating an average. then a voltage decider calculation calculates a voltage (witch is v2 and usually = 3.14) then that gets converted to a char and displayed on an lcd once per second
thanks again for your time
Edit - the serialprint(b) was set for testing and will usually be serialprint(input)
Ok, understand. You can convert v2 directly into the character array like this (sticking with your variable names)
sprintf(input, "%5.2f", v2);
etc
This will format the value with two digits before the decimal point and two after.
Well it would if the arduino sprintf() supported floats, which it does not. Use dtostrf().
Doh! Thank you, Keith.
Sorry, Josh. Try this:
dtostrf(v2, 5, 2, input);
Thanks I recompiled and ran the code however on the LCD there's just a '?' (See attached picture)
I've tried using dtostrf() however that wouldn't compile at all :frowning:
ahh sorted ! thank you ! :grin:
