I was looking for a way to handle wireless communications between two Arduino boards. Other options like Xbee or Bluetooth were going to cost $50 to over $100. Then I found a cheap RF transmitter and receiver at Sparkfun. The total cost is only $9!
For a full description and all the code check out this writeup. http://www.glacialwanderer.com/hobbyrobotics/?p=291
Here's the circuit I used.
And some of the code:
// Sends an unsigned int over the RF network
void writeUInt(unsigned int val)
byte checksum = (val/256) ^ (val&0xFF);
Serial.write(0xF0); // This gets reciever in sync with transmitter
Serial.write(g_network_sig, NETWORK_SIG_SIZE);
Serial.write((byte*)&val, VAL_SIZE);
Serial.write(checksum); //CHECKSUM_SIZE
// Receives an unsigned int over the RF network
unsigned int readUInt(bool wait)
int pos = 0; // Position in the network signature
unsigned int val; // Value of the unsigned int
byte c = 0; // Current byte
if((Serial.available() < PACKET_SIZE) && (wait == false))
return 0xFFFF;
while(pos < NETWORK_SIG_SIZE)
while(Serial.available() == 0); // Wait until something is avalible
c = Serial.read();
if (c == g_network_sig[pos])
if (pos == NETWORK_SIG_SIZE-1)
byte checksum;
while(Serial.available() < VAL_SIZE + CHECKSUM_SIZE); // Wait until something is avalible
val = Serial.read();
val += ((unsigned int)Serial.read())*256;
checksum = Serial.read();
if (checksum != ((val/256) ^ (val&0xFF)))
// Checksum failed
pos = -1;
++pos;
else if (c == g_network_sig[0])
pos = 1;
pos = 0;
if (!wait)
return 0xFFFF;
return val;
