I need build or find an off the shelf item that will allow me to switch between two step down supply voltages, i.e., 1.5 volts and 12v via a logic signal. Supply would be 3A max.
For example a high signal would have the device supply 1.5 volts and low signal would have the device supply 12v. Any ideas?
Yes, I need high side switching to choose between the two supply voltages. The two options I have come up with are:
Two high side p-channel mosfets one with a "supply voltage" of 1.5 volts but would be triggered by a "LOW" or ground at the the gate. Otherwise it would be 5v at the gate. The other mosfet would have a supply voltage of 12v and high/low or 5v or ground. If this does not work out, option 2.
The 12v p-channel on one side, on the the other a DC-DC step down converter supplying 1.5v with an N-channel mosfet turning the converter off and on.
I prefer option #1 above, simpler. Getting back to my original question, can I have a 1.5v supply voltage on the p-channel mosfet with 5v from Arduino turning it off?
1.5volt on the source and 5volt on the gate (mosfet off) is 3.5volt difference.
1.5volt on the source and 0volt on the gate (mosfet on) is 1.5volt difference.
Both are within the 8volt limit.
Not sure if the mosfet can provide enough current with only 1.5volt gate drive.
Don't know if you already have cross-posted this elsewhere,
but is that 12volt coming from mains power and the 1.5volt from a battery?
Can't you use a 12volt relay with NC contacts for the 1.5volt source.
Leo..
