Choosing the correct motor for actuating a roller blind
Using an arduino, I'm building an automated blind controller. The blinds are this kind with a beaded cord. I'll fit a 3d printed gear that grips the beads onto the end of the axle. I'm completely confused by the kind of motor one should use for this purpose.
  1. the type of motor. Since it needs to go a determined distance, I figure I should use either a stepper motor or a servo. I think a servo wouldn't turn enough to pull the blind all the way up or down. But a stepper motor doesn't know where it is, so might get out of sync and damage the blind if it gets to the end.
  2. the amount of power/torque the motor requires. This motor has this spec: Torque kg./cm. (4.8V/6.0V): 1.08 / 1.30, but I have no idea how to translate that into 'it can pull a blind' or 'it will explode at the first hint of resistance'.
  3. How do you stop the blinds at the right point? Is it sufficient to use a stepper or servo and work out the rotation required, or do I need limit switches regardless? I've seen a few posts recommending limit switches, but I can't find anything that says what components I need or how they are assembled.
  1. the motor your selected is nothing for your project
  2. you need a stepper motor with enough torque and
  3. you need a limit switch (better: two) to tell the motor its start (and end) position
If your stepper motor has enough torque and there are no unforeseeable obstacles (Murphy's laws still exist ..) it will not lose any steps and if you know, that the distance, you want it to travel from the Zero-switch, is, say 5000 steps away, then this will work.
If you shut the blind only half and the Arduino is always ON, the sketch will know the stepper's current position.
If you switch the Arduino OFF, the stepper has no idea where it is and you need to reference it then first - move it backwards until it hits the Zero switch and then you can go from that point until it hits the end stop switch or you stop in between.
There might be an intelligent solution - given that you can make sure, that the stepper will never lose steps during operation - to store the current position in Arduino's EEPROM and have it read as first action (setup loop) to tell the stepper, where it is. So you could save the way back to ZERO.
The number of steps which are needed to travel a certain distance depends on the steps (or microsteps) of your stepper and the gear ration with which it is connected to your blind.
So, first you have to specify, how much torque you will need - this will then lead to the right stepper motor, the right driver and its external power supply. After that we can care about the steps needed to go a distance.
