Christmas light controller
I am trying to build a Christmas light controller using this setup: GitHub - dimecoin/XmasFHT: Use Arduino to control xmas lights (with relay) from audio source using FHT
Everything is going well, but I am getting lots of noise on the circuit - nothing connected to the audio input, but getting readings on the serial monitor.
Attached is my translation of the schematic included in the link onto a breadboard. I will freely admit I am not very good at translating schematics.
Have I missed the translation of the schematic? How can I reduce the noise on the circuit?
If I have posted this in the wrong area, please correct me.
Thanks all!
Welcome to the forum.
The OPs diagram.
You do need that green wire, as it forms part of the potential divider to feed your variable audio voltage to A0.
What are your component values?
What do you mean by noise?
If the green wire is not connected then it is possible that is where the noise is coming from.
What do you see on the serial port?
Do you have a DMM?
Thanks.. Tom.. :slight_smile:
is this accurate ?
Hi Tom, thanks for the reply.
By noise I mean there is data scrolling through the serial monitor, even with nothing connected - No audio. Even with the A0 wire disconnected from the Nano, I still have data on the serial port.
I do have the green wire connected. On the audio Pot, I have the middle leg going to A0, one outside leg going to ground and the other outside leg going to the positive terminal of the headphone jack.
In the serial port, I see eight columns of numbers, corresponding the eight octaves setup by the program. I have attached a screenshot.
Forgive my lack of understanding, but I don't know what a DMM is.
Dave - I tried your configuration and it doesn't really change anything. Still the same behavior in the Serial port.
DMM = Digital Multi Meter
Ok, I feel really stupid now :-[ . Yes, I have many.
tamarackghost:
Can you post your code using code tags.
The reason your screen is scrolling data is probably because the original writer had it set that way, it is probably serial printing on every sample from A0.
So it will not necessarily be noise, just the AtoD output.
* Christmas Light Controller & Real Time Frequency Analyzer based on FHT code by Open Music Labs at http://openmusiclabs.com
* Then modified by PK from : https://dqydj.com/build-your-own-real-time-frequency-analyzer-and-christmas-light-controller/
* Modified by dimecoin: https://github.com/dimecoin/XmasFHT
* Requires FHT library, from here:
* 	http://wiki.openmusiclabs.com/wiki/ArduinoFHT
// Easy Customizations
// Adjust the Treshold - what volume should make it light up?
#define THRESHOLD 35
// Old way if you want to statically set this.
// Attempt to 'zero out' noise when line in is 'quiet'.  You can change this to make some segments more sensitive.
// defaults:
// { 100, 81, 54, 47, 56, 58, 60, 67 };
//int oct_bias[] = { 136, 107, 44, 47, 56, 58, 60, 77 };
// New Auto calibration.
uint8_t oct_bias[] = { 0, 0, 0, 0, 0, 0, 0, 0 };
uint16_t cal_bias[] = { 0, 0, 0, 0, 0, 0, 0, 0 };
/* Number of times to sample the "natural noise" on wires to get average.
 * This average is used to cancel out noise while running.
 * Don't call to many times or will be slow to startup.
 * Dont' call over 16777215 or so times or it might overflow (plus would take forever to startup).
	ie. 256 (max reading) * CAL_TIME needs to be <= (2^32)-1 (size in bits of unint16_t)
#define CAL_TIME 100
// Divide Threshold by 2 for top octave? 1 - yes 2 - no.  Makes highest frequency blink more.
#define TOP_OCTAVE_DIVIDE false
// This is for ACTIVE HIGH relays (works with LEDS for testing), switch values if you have ACTIVE LOW relays.
#define ACTIVE_ON HIGH
#define ACTIVE_OFF LOW
// enable for serial mode output, comment out to speed up lights
#define DEBUG
// Timer/delay for self test on startup.
#define SELFTESTTIME 100
// Hard Customizations - know what you are doing, please.
// FHT defaults - don't change without reading the Open Music Labs documentation at openmusiclabs.com
#define LOG_OUT 1		// use the log output function
#define FHT_N 256		// set to 256 point fht
#define OCTAVE 1
#define OCT_NORM 0
// include the library, must be done after some of the aboves are defined.. (required by FHT, won't work if included in wrong order)
#include <FHT.h>
// Delay - defines how many cycles before the lights will update.  OML's algorithm at 256 samples (needed for our 8 octaves) takes
// 3.18 ms per cycle, so we essentially throw out 14 cycles (I used mechanical relays, you can lower this for solid state relays).
// 15 cycles = 47.7 ms update rate.  Be careful here and don't change it too quickly!  I warned you!
// Default is 15
#define DELAY 15
// Don't change NUM_PINS.  FHT outputs 8 octs.
#define NUM_PINS 8
// Pin configuration, there is only 8 channels here.  Add duplicate entries if you don't have 8 lights, must be 8!
int relayPins[] = { 2, 3, 4, 5, 6, 7, 8, 9 };
uint8_t x[NUM_PINS];
void frequencyGraph(uint8_t x[], int size);
	// pin setup
	for (int i = 0; i < NUM_PINS; i++) {
		pinMode(relayPins[i], OUTPUT);
		digitalWrite(relayPins[i], ACTIVE_OFF);
	// quick self test
	for (int i = 0; i < 2; i++) {
		for (int j = 0; j < NUM_PINS; j++) {
			digitalWrite(relayPins[j], ACTIVE_ON);
			delay(SELFTESTTIME);
			digitalWrite(relayPins[j], ACTIVE_OFF);
#ifdef DEBUG
	while (!Serial) {
#endif
	TIMSK0 = 0;		// turn off timer0 for lower jitter
	ADCSRA = 0xe5;		// set the adc to free running mode
	// This is setting up A0 - dime
	ADMUX = 0x40;		// use adc0
	DIDR0 = 0x01;		// turn off the digital input for adc0
  Loop - includes initialization function and the full loop
	// True full loop
	int q = 0;
	int cal = 0;
	while (1) {		// reduces jitter
		cli();		// UDRE interrupt slows this way down on arduino1.0
		for (int i = 0; i < FHT_N; i++) {	// save 256 samples
			while (!(ADCSRA & 0x10)) ;	// wait for adc to be ready
			ADCSRA = 0xf5;	// restart adc
			// This is his way of reading Analog 0 (A0).  It pulls in L[ow] and H[igh] bit. - dimecoin
			byte m = ADCL;	// fetch adc data
			byte j = ADCH;
			int k = (j << 8) | m;	// form into an int
			k -= 0x0200;	// form into a signed int
			k <<= 6;	// form into a 16b signed int
			fht_input[i] = k;	// put real data into bins
		fht_window();	// window the data for better frequency response
		fht_reorder();	// reorder the data before doing the fht
		fht_run();	// process the data in the fht
		fht_mag_octave();	// take the output of the fht
		sei();
		// We are in calibration mode.
		if (cal < CAL_TIME) {
			for (int i = 0; i < NUM_PINS; ++i) {
				cal_bias[i] += fht_oct_out[i];
#ifdef DEBUG
			Serial.print(F("Calibrating "));
			Serial.print(cal);
			Serial.print(F("/"));
			Serial.println(CAL_TIME);
#endif
			cal++;
			continue;
		// Calibration mode has just ended, crunch data collected.
		if (cal == CAL_TIME) {
				oct_bias[i] = (uint8_t) (cal_bias[i] / CAL_TIME);
#ifdef DEBUG
			Serial.println(F("--------------------------------------"));
			Serial.println(F("Done with Cal"));
				Serial.print(oct_bias[i]);
				Serial.print(" ");
			Serial.println(F(""));
				Serial.print(fht_oct_out[i] - oct_bias[i]);
				Serial.print(F(" "));
			Serial.flush();
#endif
			// Ready signal.
				digitalWrite(relayPins[i], ACTIVE_ON);
			cal++;
			continue;
		// Normal play mode
		if (q % DELAY == 0) {
				x[i] = fht_oct_out[i] - oct_bias[i];
			frequencyGraph(x, NUM_PINS);
#ifdef DEBUG
				Serial.print(x[i]);
#endif
		++q;
void frequencyGraph(uint8_t x[], int size) {
	int top_threshold = THRESHOLD;
	for (int i = 0; i < size - 1; i++) {
		x[i] = max(x[i], 0);
		// Special logic for last pin
		if (TOP_OCTAVE_DIVIDE && i == (size - 1)) {
			top_threshold /= 2;
		if (x[i] >= top_threshold) {
		} else if (x[i] < top_threshold) {
			// && digitalRead(relayPins[i]) == ACTIVE_ON ) {
With nothing attached, I anticipated no data. No data, or at least data below the threshold, means my relay will be inactive. The relay is still tripping because of what I am calling "noise". And, when I attach the audio, none of the numbers are changing. So, I obviously have something wrong with the wiring, or at least that is my thought.
