Circuit simulation and code windows - software
Hi, I have seen this software that allows you to run a full simulation and step through your code with it. I have been searching for this but I can't find anything. Please see attached.
Can anyone please suggest where I can download or buy this from?
Thanks, Daniel.
Tinkercad: https://www.tinkercad.com/.
You need to sign up for a autodesk account.
It is the only simulation that I use, because it is the only simulation that works. It has limitations, but it is fun to try small things.
An old slow computer might have troubles, because the simulation needs a fast browser/computer.
Click on the left: Circuits
Make a new circuit.
Give it a better name in the upper-left corner.
Drag the Arduino Uno from the right into the workspace.
Click "Blocks" and select "Text" for a normal sketch.
You will see a sketch to blink a led. Start the simulation and check if you see the 'L' led blinking.
Brilliant, thank you
