Circuit to Control Fan with Ozone Sensor (120v AC fan, PWM, Arduino Uno R3)
I have been trying to create a circuit using an Arduino Uno R3 SMD, an Orion OA80AP-11/22-1WB Fan (115-230 VAC), a MIKROE-2767 Ozone 2 Click ozone sensor, and a Krida PWM AC Voltage Dimmer (50hz-60hz/80-240 VAC) relay. I have breadboards, wires, and a standard 120 v wall plug to use.
I would like the circuit to adjust the speed of the fan depending on the measured concentration of ozone, which will reach up to 100 ppm for the circuit's application (I will not be exposed to this level of ozone; it will be confined to a chamber. Ideally, if the ozone concentration is at 100 ppm, the fan will operate at full speed, if the ozone concentration is between 50-99 ppm it will operate at half speed, and the fan will be off if the ozone concentration is below 50 ppm.
Because I am dealing with 120 VAC, I would like some advice from someone who is more familiar with circuits than me. Advice on how to setup the circuit and what code to use would be greatly appreciated. Thanks!
Links to mentioned products below.
Arduino Uno SMD R3: A000073 Arduino | Development Boards, Kits, Programmers | DigiKey
Orion Fan:
OA80AP-11/22-1WB Orion Fans | Fans, Blowers, Thermal Management | DigiKey Marketplace
Ozone Sensor: MIKROE-2767 MikroElektronika | Development Boards, Kits, Programmers | DigiKey
Dimmer relay:
Before you get too far with this project, get the fan and the dimmer and see if the fan can really be slowed down. Most such fans convert the AC input to DC and use that to power the electronics in the hub to turn the fan. I doubt changing the AC sine wave with a dimmer will have the effect you want.
I think he might be right. I can't confirm it from the datasheet, but it seems like an ACDC fan.
You might consider something like this:
https://www.digikey.com/en/products/detail/orion-fans/OD8038-12HBVXC10A/2621174
12vdc power (24 and 48vdc are available), and it takes a 5v pwm input for fan speed. No need to mess with AC or the dimmer relay.
I will consider this. The main reason I went with the 120V fan is because the the circuit will be running for hours at a time without being connected to a computer, meaning an on-board power supply will be needed. The project description requests that the circuit be powered by an outlet.
You would supply the 12v with something like this:
https://a.co/d/irV4kPu
And the Arduino would give the PWM 0-5v for input.
One way or the other, something has to plug into 120v, it’s just that this unit will take PWM input and you wouldn’t need the dimmer controller.
