Hello, i'm new on this forums and need help of you guys,
I don't know if this is the correct section or even if this is the apropriate place to put my question
I have a project of a simplistic ACPI controller using a Arduino board, the arduino will switch on/off a 5v/3A power supply.
I have a basic knowloge of electronics and i prefer to use my own solutions instead a pre-built module because of the price. (Since the hole project is aimed at low price).
But, if possible, i like to use something that waste less power as possible at the output (i like to get as close as possible to 5v/3A at the output).
I readed about PNP/NPN transistors but i dont know if exists transistor for this kind of power, i've only found schematics for 1A at top.
I've also readed about using relays but it's need a secodary transistor to drive it and make noise when switch on/off, so, i prefer to not use them.
