I build myself a working "HV fuse doctor" (see http://www.instructables.com/id/HV-Rescue-Simple/ ) and was wondering one thing: How do I program an attiny13a to use the reset pin?
Is this the right answer:
Upload the sketch to the attiny13 (as I always do) and burn the fuses afterwards to disable the reset pin? (related answer found here Attiny84 Reset Pin - Just A Quick Check - Microcontrollers - Arduino Forum )
If not or if I can use the "HV fuse doctor" to program an attiny13a, please point me the direction.
Thanks & best
PB5/D5/A0 is attached to the reset pin. There's nothing special you need to do, other than using some of the peripherals on this pin. You just need to set the RSTDISBL fuse.
Once you disable it, I think you have to use High Voltage (12V) programming to erase the fuses if you want to re-program the chip.
CrossRoads:
Or use selfprogramming - i.e. bootloader.
Smajdalf:
Generally, yeah - the attiny13 has only 1k of flash though, and the bootloader would probably take around half of that... So not really viable.
I'll go with HV programming
Not tested the self-made HV fuse doctor with attiny13a but I'm optimistic.
Best
