'class Firebase_ESP_Client' has no member named 'getString'
Hi, is anyone how to solve it?
First picture, I put <FirebaseESP32.h> first and then <Firebase_ESP_Client.h>.
Second picture, I put <Firebase_ESP_Client.h> first and then <FirebaseESP32.h>.
The different arrange will show different error message. Both libraries are needed, cannot remove either one. Can anyone help me? TQ
Probably only if you post the code properly, using code tags (this button in the forum editor window </> )
#include <SPIFFS.h>
#include "esp_camera.h"
#include <WiFi.h>
#include "Arduino.h"
#include "soc/soc.h"           // Disable brownout problems
#include "soc/rtc_cntl_reg.h"  // Disable brownout problems
#include "driver/rtc_io.h"
#include <FS.h>
#include <Firebase_ESP_Client.h>
#include <FirebaseESP32.h>
//Provide the token generation process info.
#include <addons/TokenHelper.h>
//Replace with your network credentials
const char* ssid = "****";
const char* password = "****";
// Insert Firebase project API Key
#define API_KEY "****"
// Insert Authorized Email and Corresponding Password
#define USER_EMAIL "****"
#define USER_PASSWORD "****"
// Insert Firebase storage bucket ID e.g bucket-name.appspot.com
#define STORAGE_BUCKET_ID "****"
// Photo File Name to save in SPIFFS
#define FILE_PHOTO "/data/photo.jpg"
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
// OV2640 camera module pins (CAMERA_MODEL_AI_THINKER)
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
boolean takeNewPhoto = true;
//Define Firebase Data objects
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseConfig configF;
bool taskCompleted = false;
// Check if photo capture was successful
bool checkPhoto( fs::FS &fs ) {
  File f_pic = fs.open( FILE_PHOTO );
  unsigned int pic_sz = f_pic.size();
  return ( pic_sz > 100 );
void startCameraServer();
// Capture Photo and Save it to SPIFFS
void capturePhotoSaveSpiffs( void ) {
  camera_fb_t * fb = NULL; // pointer
  bool ok = 0; // Boolean indicating if the picture has been taken correctly
  do {
    // Take a photo with the camera
    Serial.println("Taking a photo...");
    fb = esp_camera_fb_get();
    if (!fb) {
      Serial.println("Camera capture failed");
      return;
    // Photo file name
    Serial.printf("Picture file name: %s\n", FILE_PHOTO);
    File file = SPIFFS.open(FILE_PHOTO, FILE_WRITE);
    // Insert the data in the photo file
    if (!file) {
      Serial.println("Failed to open file in writing mode");
    else {
      file.write(fb->buf, fb->len); // payload (image), payload length
      Serial.print("The picture has been saved in ");
      Serial.print(FILE_PHOTO);
      Serial.print(" - Size: ");
      Serial.print(file.size());
      Serial.println(" bytes");
    // Close the file
    file.close();
    esp_camera_fb_return(fb);
    // check if file has been correctly saved in SPIFFS
    ok = checkPhoto(SPIFFS);
  } while ( !ok );
void initWiFi(){
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.print("Camera Ready! Use 'http://");
  Serial.print(WiFi.localIP());
  Serial.println("' to connect");
void initSPIFFS(){
  if (!SPIFFS.begin(true)) {
    Serial.println("An Error has occurred while mounting SPIFFS");
    ESP.restart();
  else {
    Serial.println("SPIFFS mounted successfully");
void initCamera(){
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  if (psramFound()) {
    config.frame_size = FRAMESIZE_UXGA;
    config.jpeg_quality = 10;
    config.fb_count = 2;
    config.frame_size = FRAMESIZE_SVGA;
    config.jpeg_quality = 12;
    config.fb_count = 1;
  // Camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    ESP.restart();
void capture(){
  if (takeNewPhoto) {
    capturePhotoSaveSpiffs();
    takeNewPhoto = false;
  delay(1);
  if (Firebase.ready() && !taskCompleted){
    taskCompleted = true;
    Serial.print("Uploading picture... ");
    //MIME type should be valid to avoid the download problem.
    //The file systems for flash and SD/SDMMC can be changed in FirebaseFS.h.
    if (Firebase.Storage.upload(&fbdo, STORAGE_BUCKET_ID /* Firebase Storage bucket id */, FILE_PHOTO /* path to local file */, mem_storage_type_flash /* memory storage type, mem_storage_type_flash and mem_storage_type_sd */, FILE_PHOTO /* path of remote file stored in the bucket */, "image/jpeg" /* mime type */)){
      Serial.printf("\nDownload URL: %s\n", fbdo.downloadURL().c_str());
    else{
      Serial.println(fbdo.errorReason());
  initWiFi();
  initSPIFFS();
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
  initCamera();
//Firebase
  // Assign the api key
  configF.api_key = API_KEY;
  //Assign the user sign in credentials
  auth.user.email = USER_EMAIL;
  auth.user.password = USER_PASSWORD;
  //Assign the callback function for the long running token generation task
  configF.token_status_callback = tokenStatusCallback; //see addons/TokenHelper.h
  Firebase.begin(&configF, &auth);
  Firebase.reconnectWiFi(true);
    if (Firebase.getString(flashData, "/ESP32_APP/flash")){
    Serial.println(flashData.stringData());
    if (flashData.stringData() == "1") {
    capture();
    delay(700);
  else if (flashData.stringData() == "0"){
    digitalWrite(flashPin, LOW);
//    delay(10);
They are two separate libraries. You CAN'T use them both in the same sketch. Pick one and modify the rest of the sketch to work with it.
But both libraries are needed. I have no idea while modify the sketch. Are there any libraries that consists of "getString" and "Storage"? Or can I combine both libraries?
