Dear all,
First of all thank you for reading this.
Before posting I did my maximum with everything I read. I just subscribed to the forum since i found every information needed until now just by browsing.
I found this link WIFI Shield firmware update 1.0.5 attempt - Networking, Protocols, and Devices - Arduino Forum with the similar problem but until now i do not found the right reason and solution since this topic mix a lot of problems.
I decided to upgrade the wifi shield according the tutorial: http://arduino.cc/en/Hacking/WiFiShieldFirmwareUpgrading
I tested the procedure under Mac and Windows and I got exactly the same issue.
I use the drivers coming from 1.6.4 version of the Arduino program.
Every step of the procedures is successful on the screen.
But I get a very strange hardware behavior and I would like to exchange with you:
- I first upgrade the wifi_dnld.elf. Under windows the batchisp executable explains me that everything pass. At the end of this upgrade, the "LINK" led becomes green 4 seconds and then light off. The "DATA" led becomes blue and stays blue.
c:\Program Files (x86)\Atmel\Flip 3.4.7\bin>batchisp.exe -device AT32UC3A1512 -h
ardware usb -operation erase f memory flash blankcheck loadbuffer "C:\Program Fi
les (x86)\Arduino\hardware\arduino\avr\firmwares\wifishield\binary\wifi_dnld.elf
" program verify start reset 0
- Then I reset the board (only solution to get the board seen by Windows back). I then upgrade the wifiHD.elf and then everything satsy lighten off. No led.
les (x86)\Arduino\hardware\arduino\avr\firmwares\wifishield\binary\wifiHD.elf" p
- Then I shutdown everything,I move the jumper, I reconnect the arduino (I removed the mini usb cable) I try to test the shield with a dummy program (ConnectWithWPA) and i obtain the "No Wifi Shield Connected " message
4 hours this sunday morning, nearly get nervous breakdown ![]()
Thanks a lot !
